03-24-2005, 12:51 PM | #1 |
Rock Stacker Join Date: Feb 2005 Location: Houston
| Reverse wound mag mayhem?
I have an emaxx tranny and was wondering if i bought 2 reverse wound mag mayhems if they would work?
03-24-2005, 01:04 PM | #2 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
why would you need reverse wound motors?will it be turning the reversed direction?if so then they should work
03-24-2005, 02:08 PM | #3 |
there the only ones that tower has in stock and my jugg coms in on saterday. i dont want to wait for them . they do spin backwards... i think
03-24-2005, 02:38 PM | #4 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
it shouldn't matter because the maxx gears are all straight cut. so it doesn't matter which way it runs. you will just need to flip the trans around possibly in the truck
03-24-2005, 03:12 PM | #5 |
| lathe motors or 14.4v motors
which would be better 2 integy 55t motors or a 14.4v drill motor |
03-24-2005, 04:40 PM | #6 | ||
03-25-2005, 06:49 AM | #7 |
if you use the reverse motors in your jug they will not perform as they should cause the timing will be retarded instead of advanced like it should be.it can also run hotter.how much i don't know as i never ran a motor in reverse timed
03-25-2005, 04:22 PM | #8 |
Ok well i might just wait till tower has them back instock then
