![]() | #1 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
My front motor started smoking today. I took it out for a 5 min spin and it was smoking lightly and that great burning smell was there. I checked the pinion mesh and it was good. There's barely any friction in the axle since i just lubed every bearing and gear. Turning the tires by hand with the motor installed is a little harder than normal. I broke in the motors with water when i first got em and oiled the bearings. They've been used about 10-15 times so far, mostly on rocks but a few water crossings as well. The motors did get submerged once or twice. There are sparks near the comm, but not continuous. Power and speed is noticeably weaker/slower. The front spins slightly faster than the rear (when motor is installed). Does this seem rather early for the motors to go bad or need maintained or is this the norm? I've never maintained a motor before and based on my research, i need to inspect the brushes, cut the comm., and lube the bushings/bearings. I don't have the parts or equipment to do this (i do have 3 in 1) so that's not gonna happen right now. I read that a few dipped them in water to clean the brushes and they ran better so i was thinking of trying this again and see what happens. What you guys think is going on with my motors? Edit: i forgot to ask this. Will running the motors in a glass of water with the esc and speed control cause damage to any of these components? I read about this happening to some but then others do it without a problem. I have the evx esc. Last edited by muddeprived; 06-10-2007 at 06:41 PM. |
![]() | #2 |
I wanna be Dave Join Date: May 2006 Location: akron
no way 15 minutes of running should smoke any motor. unless it is really overgeared or somthing is not rolling right. check the comm is it black? if so clean it with some light sand paper or a comm stick or one of those green pads for dishes. you can just chuck it up in the drill and spin it dont go crazy all you want to do is take off the black. if the comm is not black somthin else is wrong.
![]() | #3 | |
| ![]() Quote:
![]() | #4 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
That many times with that long of runs equals about 20 hours of run time. Sounds like you are due for a brush change and comm. true up.
![]() | #5 |
Quarry Creeper ![]() Join Date: Nov 2005 Location: The Great White North
What gearing are you running in the axles? And what motors are they?
![]() | #6 | |
| ![]() Quote:
10 tooth pinions, stock clod gearing, integy lathe 55t's. I inspected the comm (visually) and both were black as black can be. The rear motor had black debris (powder) around the top of the can near the comm. I ran them in water until the comm. got it's original copper color back. I haven't tested them yet.... | |
![]() | #7 |
That black debris is carbon dust from your brushes.
![]() | #8 |
![]() | #9 |
It could be from a number of things like brush spring tension, brush/ holder alignment and polarity (+/-) of the brush. Check to see if the motor shaft bearing is loose or wore to one side. Most times it's brush spring tension. Pull your brushes and see if the wear pattern is the same or if one brush is longer than the other.
![]() | #10 |
Update: After cleaning them in water, i swapped the rear motor to the front and vise versa. ![]() ![]() i dunno what i did but it sure has more power than it did on it's first run. I couldn't do wheelies with it before. |
![]() | #11 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
Running a motor in water does more than just clean it.. It seats the brushes better to the comm for better conductivity... That's why it's doin' wheelies now... It's makin' a bit more power 'cos the brushes are more efficient in gettin' the power thru the motor...
![]() | #12 | |
| ![]() Quote:
![]() ![]() Thanks for the help ya all ![]() | |
![]() | #13 |
Also could be that oil got in the comms or brushes and that why it was smoking, i had the same problem with a friends rig, he brought it to me and the motors was producing a lot of sparks and smoke + it had no power, he thought his motor was toast ![]() ![]() ![]() |
![]() | #14 | |
| ![]() Quote:
![]() | #15 |
That sounds like a good possibility, too... WD40 isn't a motor lube... It's not really a lube at all as it evaporates over time... 'Sides... I'm not a big fan of fish oil on my stuff...;) 3 in 1 is good to use, yep... But after you get it wet and before you oil it, you should blast it out with some motor spray... Help get all the dust, residual water and left over oil out... Then you'll have a nice clean motor to oil and run... Plus it's also a good time to check yer brushes and comm and see if the need a stick run over them or not... And the motor spray will help ya keep from over-oiling it, too... ![]() |
