06-11-2007, 03:05 PM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
| BEC issue...what are my options?
Hey! I'm using the LRP waterproof ESC (for now) along with 2 HiTec 645's and that Futabe 4WD 4ch receiver and a lathe motor...whatever the normal turn is 55? I don't have enough power to use both servos at the same time and still drive forward and reverse. I do not want to add a secondary battery pack to power the receiver; no where to put it. I will be adding a 3rd servo for front dig in the near future. The battery pack I'm using is a 6AA 2400MaH NiMh. What are my options? Can I just run the reveiver and ESC in paralell off the same pack? |
06-11-2007, 03:54 PM | #2 |
Quarry Creeper Join Date: Jan 2007 Location: Alberta, Canada
I thought receivers and servos can run off of 7.2V? I like the SportBEC from dimension engineering, but like I said, I think servos and receivers can run off 7.2V. |
06-11-2007, 04:29 PM | #3 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
I think there is a voltage regulator so you can use the main pack and it will put out like 6v 5amp or something. I dunno where, i've just read stuff here.
06-11-2007, 05:01 PM | #4 |
Well I guess 7.2V is nominal, and that's pushing the upper limit for a receiver I think. Maybe that's why a BEC is used then. But yeah, SportBEC is what I like. But I'm a robot builder, not a crawler driver (almost said pilot there!). |
06-11-2007, 05:31 PM | #5 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
Search this section for MPI Regulator. It will solve all your problems.
06-11-2007, 05:38 PM | #6 | |
How To: Installing an MPI voltage regulator Last edited by Grizzly4x4; 06-11-2007 at 05:50 PM. | |
06-11-2007, 05:45 PM | #7 |
Rock Crawler Join Date: Jun 2006 Location: Dallas, Oregon
this little doo dad is exactly what your looking for! i believe its only rated to 7 maybe 8 cells so you should be alright! oh and its dirt cheap!! http://www2.towerhobbies.com/cgi-bin...?&I=LXJJF6&P=7 |
06-11-2007, 09:23 PM | #8 | |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
The Novak unit only puts out 3 amps, not enough for the 3 servos he is wanting to use. It is 7 cell max too. It will do 8, but not for long MPI is the best bet for now. I will be trading in my Novak regulators for the Castle Creations one whenever they decide to release it. | |
06-11-2007, 10:02 PM | #9 |
I would also recommend the MPI unit for now.
06-12-2007, 11:49 AM | #10 | |
| Quote: Thanks bub! I'll get this stuff on order. The only thing that sucks is when I built this chassis, I didn't leave much (well any) room for additional electronics. Luckily that stuff looks small... | |
06-12-2007, 12:07 PM | #11 |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
And actually the rear steering isn't allowed in competion for a 2.2 You could eliminate that rear servo for now, that should be ok, until you get the dig set-up. |
07-03-2007, 06:40 AM | #12 |
Update. I got things wired up and all is well. It works like it should. Thanks all! One question though...If I essentially split the incoming power lead to power both the Rx and ESC seperately, why do I need a voltage regulator? The pot on the regulator is turned all the way up to give the Rx the 7.34vdc. Couldn't I have just saved the $40, the weight, and the wiring and just left it out? All I would've had to do was remove the signal wire from the ESC connector and tapped off the main incoming battery leads.
07-03-2007, 08:32 AM | #13 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
07-03-2007, 09:07 AM | #14 | |
I suggested the voltage reg to you because I didn't want you to burn up a bunch of servos and learn about the problems the expensive way, like I did. | |
07-03-2007, 11:24 AM | #15 |
That's fair. I was sure there was a reason, but wasn't sure exactly why. What would your suggestion be for a dig servo for that R2? I like nice stuff...
07-03-2007, 11:43 AM | #16 | |
http://www.hitecrcd.com/servos/show?name=HS-81MG | |
07-03-2007, 02:30 PM | #17 |
Good to know. Thanks!
