clod stall forever????? Whats up with clod stall?? I put 2 Momba Max speed controlls in my crawler and it did absolutly nothing to help with clod stall. I wired one to the front and the second to the rear. and wired both speed controlles to a single 6 cell 4500 battery. |
First mistake: its a clod, Its going to stall. Second mistake: Wiring Two controlers two one battery. |
Hmm...I don't see those as mistakes at all. Running one battery off two controllers is perfectly fine. I know many people here that do it, including myself and have no issues with it whatsoever. My clod stall, if I have any at all, is so minimal it's not even an issue for me. |
Shows what I know, I only know that clods are junk! :lol: |
my cars pushing 12 to 14 lbs. rapter axle, aluminum bead locks, tube chassis, how do you have everything wired? i only get a 10 minute run time. |
crawlers suck. ive built 2 and this has been my more expensive one, over $2000 invested and i cant get it to work good. my first one rocked. |
I run 102 to one in my 25 -30 pounder on 3300 cells, I get ATLEAST 45 mins to an HOUR. On a huge outrunner (3025), blastin lines up the mountain. 15 mins on 4400??? What motors are you running. sounds to me like you need a higher turn lathe motor... or something with POWER.... maybe a JRH motor? |
ive got 2 integi 65t motors, 2 momba max speed controlls, 4500 battery, hi tech 645 in the rear, hi-tech robot servo up front, rapter axles, alumi bead locks. the works |
Calm down man, You don't just buy a bunch of parts and expect it to work well. It takes time. If you want a crawler that you don't have to build and it works sweet then I would suggest hitting up one of the vendors here or goin to e-bay. But I have to say, My $8 chassis, $10 axles and all my electronics in all my rigs does not even come close to $1000. And I bet The Wheelchair can go where you couldn't dream. It takes time to get it all right. Good luck with it man. |
and im running 8 tooth pinions |
You are running a reciever pack right? The mambas have WEAK BEC. What gearing though? |
ive already built a sick crawler that i had no problems with. i wanted to upgraed to better parts os i wasnt breakin axle parts. my old car was the bomb |
i dont know the gearing. just a 8 tooth with whatever the rapter axles are |
and i have a very good rechargable reciever pack |
I would think you would get alot more runtime with that setup. When running a BEC, alot of your motor battery power is converted into heat, from being stepped down to the 5 or 6 volts the mamba puts out... Running a reciever pack is mandatory with that robot servo. Its a power sucker! |
Well then I am sorry I wasted your time. You have really bad drag or something? Do things get hot? Motors? ESC's? Battery? |
thats what i thought. do you think i should take the extra weight and run 2 batterys? one to each speed controll? |
they do get hot |
I have found the best way to eliminate clodstall is go brushless. Gear it as low as possiable. I run 2 esc's, one battery, if you run 2 packs the rear pack will discharge faster because it draws the most amps trying to push the rig around. Half your problem I would say is the Raptor axles as they were not properly engineered, gear ratio too high. |
i did notice a difference in speed when i got the new axles |
