07-29-2007, 03:29 PM | #1 |
Pebble Pounder Join Date: Aug 2005 Location: lake winola
| newb looking for motor help
just upgraded out of nylints and have a clod based truck now. i havent been into electric r/c in about 15 years so im a bit rusty. i have 9 tooth pinions what turn motor should i get? and what exactly do the different # of turns mean/do? thanks
07-29-2007, 05:36 PM | #2 |
Rock Crawler Join Date: Apr 2007 Location: LaSalle
I'M not a clod man so i cant answer what turn motor to get. But the higher the # of turns the slower the motor will go but it will bring more torque the higher # of turns you go.
07-29-2007, 06:06 PM | #3 |
i see so i would want the highest i can get or will that be to slow?
07-29-2007, 06:17 PM | #4 |
Oh no the highest and 85t (i think) would make your clod do about 1 mph i think most people run 45t motors on their clods.
07-30-2007, 12:27 AM | #5 |
I would use 55t with the 9 tooth pinions, but it depends on your voltage too.
07-30-2007, 07:33 AM | #6 |
i ordered a pair of 45t lathe. i will prob just be running a reg 7.2v batt.
07-30-2007, 07:58 AM | #7 |
What esc will you be using?
07-30-2007, 09:27 AM | #8 |
it came with a moped v16r. from what ive read it should work
07-30-2007, 09:33 AM | #9 |
yea it should be fine. will you be running 4ws? if you do ya might have to run a rx pack.
07-30-2007, 12:43 PM | #10 |
yeah i will be running 4ws. just got a tq3 off ebay and ordered the switch thing forom the crawler store. i figured on having to use a rx pack.
07-30-2007, 01:48 PM | #11 |
Pebble Pounder Join Date: Dec 2006 Location: nampa
sorry for stealing your thread but why use a RX pack why not just throw another cell or 2 on your batt? i just dont understand the RX pack on a elec that already has a power source |
07-30-2007, 02:11 PM | #12 |
Because on a moped you can only run 7 cells max so thats where the rx comes in place.
07-30-2007, 03:17 PM | #13 |
alright that makes sence thank you |
08-01-2007, 08:50 AM | #14 |
Pebble Pounder Join Date: Apr 2005 Location: England
wel tht is not right with 4ws running 2 servo's the bec in the moped will not be able to handle it therefore you have to run an rx pack as this can provide the Amps needed sometimes even a Y harness is better so the amps dont have to run throught your receiver |
