Thread: 11.1 lipo for tekin rebel 2?
Old 08-31-2007, 10:08 AM   #1
Default 11.1 lipo for tekin rebel 2?
Can Y use 11.1 lipo with a tekin rebel2 with two 65T motors? or I will burn the whole thing.
kazi is offline   Reply With Quote
Old 08-31-2007, 10:12 AM   #2
tekin rebel 2 doesn't support lipo cutoff so you would need a circuit that cuts off the battery before it gets damaged. try an FX series instead:
http://www.teamtekin.com/fx.html
BrandonW is offline   Reply With Quote
Old 08-31-2007, 10:47 AM   #3
It's not that I'll rum for long sessions, my new stick batteries have not arrived and I just wanted to plug a battery to see if everything works fine, and the only I have with same conector is the 11.1V Lipo
Old 08-31-2007, 10:57 AM   #4
TCS/Holmes Hobbies
SVEN's Avatar
I would not run more than 6 cells (7.2V) on a TR2 if you plan on using the BEC.
SVEN is offline   Reply With Quote
Old 08-31-2007, 11:45 AM   #5
ok thank's for the imput, I'll wait the batteries to arrive or borrow some from a friend.
Old 08-31-2007, 12:44 PM   #6
[HOONIGAN]
Wrecker's Avatar
I've seen an 9.9 volt a123 pack with a turbo on it bumped up to 14.4 volts with a 19t motor and a tr2 on a pede. The esc did just fine for the whole pack (even with using the bec). Now I'm not saying that it could repeatidly do that, or that it was not hurting it, but it survived. It was freakin HOT though!!! It sure did make it seem like that pede had a brushless system in it though, cause holy chit it was fast!
Wrecker is offline   Reply With Quote
Old 08-31-2007, 11:23 PM   #7
DANALLY's Avatar
I Damagd A Rebel 2 Running 9 Cell Sub C. That Is 10.8 Volt. The Box Says Only Up To 8 Cell Stk & 10 Cell Mod. I Sent It Into Tekin For Repairs And They Said The Damage Done Was Likely Due To The Power I Sent To It. I Now Run An 8 Pack Sub C (9.6 Volt) On Two 65t Motors. Not A Problem Since.
DANALLY is offline   Reply With Quote
