Thread: mamba max just jerks....
Old 08-31-2007, 09:11 PM   #1
Default mamba max just jerks....
I set up my mamba max as the directions describe and it just jerks when I pull the trigger. What is wrong? The setup is a dx3, MM, 55t, 7 AAs.
nigels_world is offline   Reply With Quote
Old 08-31-2007, 09:12 PM   #2
Make sure the motor setting is not on Brushless. Check that first.
Old 08-31-2007, 09:13 PM   #3
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Yes, they come in brushless mode. Luckily you have batteries that wont push many amps, or you could have fried some things!
JohnRobHolmes is offline   Reply With Quote
Old 08-31-2007, 09:17 PM   #4
When i get to that part of the setup it doesn't give me the option. Its like it leaves the setup at #8 (motor timing) and i don't get to access #9 (motor type)
Old 08-31-2007, 09:21 PM   #5
That doesn't sound right. What version of the Castle link are you using, or are you doing it manually?
Old 08-31-2007, 09:24 PM   #6
I'm doing manually because i don't feel like spending $200 on windows right now when this is all i would use it for.
Old 08-31-2007, 09:25 PM   #7
I suggest you find somebody with windows, a friend or the LHS. I dont think you can adjust motor type manually. If you have no friends or a LHS, I would do it for you.
Old 08-31-2007, 09:29 PM   #8
Well that sucks...
Old 08-31-2007, 09:45 PM   #9
Get off my lawn!
microgoat's Avatar
Perfect time to upgrade to a brushless motor
microgoat is online now   Reply With Quote
Old 08-31-2007, 10:18 PM   #10
the manual really makes it seems like you can change it manually... they tell you how. when I'm programming this thing it will randomly arm itself and leave the setup mode. why is that?
Old 09-01-2007, 12:58 AM   #11
Keep it real
Tanis's Avatar
You can do it manually, I did the first time I used it as it did the same thing to me, but something doesn't sound right on your mamba.
Tanis is offline   Reply With Quote
Old 09-01-2007, 08:30 AM   #12
Then you might not be doing it fast enough. I have never tried manual programming.
If you cant get it to complete the setup, you could try reflashing the ESC with the firmware. That still requires a windows computer.
Old 09-01-2007, 03:54 PM   #13
Programed it on a windows machine and it works great now. The drag brake and no reverse delay make all the difference in the world.
