Thread: modified MagMayhem
Old 04-15-2005, 11:58 AM   #1
felsenfest
EGRESSor's Avatar
Default modified MagMayhem
the making
dyno test
its 2bb and i used a mod Epic endbell
first timing 0*
second 10*
third 20*
and i win more then 15% efficiency compared to the stock MM
with less then 10 minutes of work
stock MM Dyno test
EGRESSor is online now   Reply With Quote
Old 04-15-2005, 03:09 PM   #2
looks good, more updates when you use it.
Magic is offline   Reply With Quote
Old 04-15-2005, 04:02 PM   #3
But you lost some torque right? Is it a good mod, trading efficiency (which I'm assuming means less current draw, which equals longer battery life) for torque?
AdamF is offline   Reply With Quote
Old 04-15-2005, 05:05 PM   #4
Colt Python/SR9c
TwistedCreations's Avatar
yes setting it to 0* timing gives it more torque and you will get better run times. just look at the lathe motors.. if you retard your timing to say, 20* , you would have gobs of torque, bu yet sacrifice the matotr dependability
BTW-= egressor- can you dyno a stock Lathe 55t motor and see how much torque it has for me?
TwistedCreations is offline   Reply With Quote
Old 04-15-2005, 06:52 PM   #5
I would like to know if you do, it would be great.
Old 04-15-2005, 07:55 PM   #6
I'm Sorry for being a NOOB, but what did you do, add bearings? Would you mind explaining a little more in depth? Please
JakeTheAlligatorMan is offline   Reply With Quote
Old 04-15-2005, 10:53 PM   #7
Colt Python/SR9c
he set it so he could change the timing on the MM motor instead of it being set at 20* timing
Old 04-16-2005, 03:42 AM   #8
its 2"bb" and i used a mod Epic endbell
bb usually stands for Ball Bearings
SPEED_RACER is offline   Reply With Quote
Old 04-16-2005, 11:13 AM   #9
TEAM MODERATOR
EeePee's Avatar
Does the difference in constant voltage have anything to do with anything?
EeePee is offline   Reply With Quote
Old 04-16-2005, 12:03 PM   #10
Colt Python/SR9c
i really dont think so. i see it raised up on the stock dyno. not very much though. with it being stock, it probably was just sucking more juice. the lower you set you timing, the less juice ya use. thats on reason why people get such good runtimes with lathes.
BTW----Jake- I'm working with Egressor right now on trying to get him his Lathe that someone was already supposed to send him. So if i can get it, he will have a dyno for it also
Old 09-28-2005, 02:18 PM   #11
felsenfest
EGRESSor's Avatar
the Dyno dont like the 55T lathe motor , rpm and amps are real slow
i´ve run it @7.2volts
the dyno shows no rpm ... torque5.0 ... watt47 ... eff%63 ... amps10.8
torque10.1 @ 14.4amps is the end , and the armature gets damned hot
