Thread: mamba max wont set up
Old 09-03-2007, 08:56 PM   #1
Default mamba max wont set up
I bought a mamba max and a 65t lathe. I wired it up like the directions say but when I go to calibrate it the esc wont stop doing the entry beaps and the light all flash at the same time and dont stop.... help me please
fathead is offline   Reply With Quote
Old 09-03-2007, 09:15 PM   #2
teamtom's Avatar
Are you trying to connect with your pc or just doing it manually?
teamtom is offline   Reply With Quote
Old 09-03-2007, 09:47 PM   #3
Do All The Lites Just Keep Flashing And Keeps On Beeping?...if so i had the same exact problem ...i called castle and they new right away that it was a "faulty programmer"so they sent me out a new one with a self addressed envelope to return the faulty one back to castle ...excellent customer service...so if you cant get it to calibrate ...i'm afraid your next move is to call castle tech....913-390-6939....hope this helps
TIMZKRAWLER is offline   Reply With Quote
Old 09-03-2007, 10:08 PM   #4
TEAM MODERATOR
Reflection's Avatar
Put new batteries in the radio,fresh charge on all cells in the truck,zero ALL trim adjustments on the radio and try again. I've got denied on setting up my Max a couple times simply because my trim adjustments were adjusted way to one side. Center all your trims,calibrate then adjust the trims again.
Hope that helps.
Reflection is offline   Reply With Quote
Old 09-03-2007, 10:09 PM   #5
that sounds like the problem. Isn't it great what a 130.00 bucks buys these days. nothing but problems. thanks for the phone number i'm calling in the morning
Old 09-04-2007, 08:42 AM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
You can also try reversing your throttle switch. Generally that is the issue when mine wont calibrate.
JohnRobHolmes is offline   Reply With Quote
Old 09-04-2007, 12:55 PM   #7
i called Castle Creations today and they are sending me a new mamba max. It seams that about 1 out of 20 have bad programming hardware. I like the customer service they offer
Old 09-04-2007, 01:07 PM   #8
Scale'n
k9popo's Avatar
Glad to hear they take care of their customers...Now put your other ESC in and lets go out...
k9popo is online now   Reply With Quote
Old 09-04-2007, 01:14 PM   #9
allready in beeeatch
