Thread: JR 8711 servo
Old 09-04-2007, 01:40 AM   #1
Default JR 8711 servo
I am new to crawling and need to find out if this servo is appropriate for crawling and if there are any issues with overheating or failures with the JR8711. with over 400 oz of torque,I figured it had the torque rating needed for most any application,but just want to make sure.Thanks in advance.
racenut123 is offline   Reply With Quote
Old 09-04-2007, 02:33 AM   #2
yes the jr ds8711 is the ticket for crawling just make sure you are using a external bec i ran a sw2 crawler with that servo in it and i love the on the demand steering it has.
YAKIMA RC RACER is offline   Reply With Quote
Old 09-04-2007, 08:58 AM   #3
Looking for scale goodies
Racer4Life's Avatar
I have the New 8711's on my Clod, and an old 8711 on my 2.2. They hve the power. Waiting on my BEC's to make them even better.
Racer4Life is offline   Reply With Quote
Old 09-04-2007, 09:59 AM   #4
Sorry, 8711.
I have a Novak goat system coming and it is suppose to have a strong enough BEC for most servos.Do you guys think this may not be the case?
Old 09-04-2007, 10:18 AM   #5
Keep it real
Tanis's Avatar
Both my daughter and I run them on our 2.2's, her's has been going strong for 5months. You might not need a regulator with the high amp BEC the Goat has, just have to try it and find out. The Mamba Max BEC couldn't handle it for more than a week, before it started wigging out and I had to go to a regulator.
Tanis is offline   Reply With Quote
Old 09-04-2007, 10:25 AM   #6
I am friends with a rep at Horizon who warned me that they had problems with this servo early on.Overheating and the like.I wanted to see what others have experienced.It looks as though you have had a good experience so far long term.Thanks for the input.
Old 09-04-2007, 10:46 AM   #7
Keep it real
Tanis's Avatar
It has gotten hot(sometimes too hot to hold my finger on), but it has worked flawlessly nonetheless. Another member of my club had one fry on him as soon as he turned it on the first time(they warrantied it for him), but I haven't had any problems with ours.
Old 09-04-2007, 10:51 AM   #8
Wow!Thats pretty hot! Are there any other servos you may recommend that may be comparable without the overheating problems?What about the 9000t?
Old 09-04-2007, 11:05 AM   #9
Keep it real
Tanis's Avatar
I haven't used the 9000t, but I will say, my servo doesn't get that hot, and my daughter's doesn't anymore either, since I wired the servo directly to the regulator, bypassing the receiver(I don't know why that made a difference). I have used the hitec5995TG, and several other weak servos(645, 5645, TP995, ST126), and I won't use any other servo now. But that is just my opinion.
Old 09-04-2007, 11:12 AM   #10
Ok good.I will just use the 8711 that I have and pray for the best. Can you point me to an area that shows how the regulators work with servos?Also what brand too? I wanna cover my bases if the Goat system BEC doesn't cut it for this servo.Thanks again!
Old 09-04-2007, 11:15 AM   #11
Keep it real
Tanis's Avatar
Here is a link to a write up Grizzly did on an MPI one.
How To: Installing an MPI voltage regulator
Also, JRH from HolmesHobbies is getting a new one from Castle Creations that's looks like it will be the best one on the market.
Edit: link
Castle BEC- review and tech thread
Old 09-04-2007, 11:21 AM   #12
I would see why after using a regulator the servo may run cooler.The demand these servos require are high and constant.A low voltage situation would more then likely cause the overheating issue.I think I will pick up one of the MPI ones just in case.Thanks for the link!
