09-16-2007, 04:47 PM | #1 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| DX6 DIG made easier
First thing, This setup is designed for a clod based truck running separate front and rear ESC's with drag brakes. (IE) Mamba 25's, Max or similar.. Using a DX6 that has had the throttle return mod done Works well with brushed motors works better with brushless I originally did this setup on Unimogers Clod after we had used JIA's method and decided it wouldn't work with the new setup that included a winch down system. This method is also easier to drive for those who are not good at multi tasking or are finger retarded like me. What it does is mix you're front and rear throttle to one stick then places dig on a 2 pos. switch You're stick setup in the end will be: front and rear throttle on the left in the "normal" throttle pos., front steer is on the right with the left/right gimbal and rear on the up/down gimbal, which is what is most comfortable for us you're left left/right gimbal will remain unused unless you with to place a winch or whatever on that channel step 1: With you're radio off press both of you're scroll, increase buttons up and turn on the radio on, this will put you into you're sub menu. step 2: Press scroll till "TYP" shows on you're screen, then press increase till "HE" appears step 3: Restart you're radio Step 4: With you're radio on press the scroll, increase buttons up at the same time to enter the sub menu Step 5: Press scroll until "HLD" shows on the screen, then press decrease to -50% Step 6: Press scroll till "CCP" shows then press increase till "off" shows, without that the truck will be impossible to drive. Programming you're ESC's ( ours were done on Mamba Max's) you will want to program the ESC's individually Flip the throttle hold button (top right) toward you plug front esc in and run setup as normal, unplug, then repeat for the rear. Front setup. 60-75% drag Rear setup 100% drag. you need this to be at 100% or you will not get the full effect of the dig All other settings Plugging in the servo's to the RX in the correct locations Front throttle=AUX Rear throttle=throttle front steer=AILE Rear steer=ELE RUD: unused unless you want a winch or lights or whatever Ger: unused To activate dig With the throttle hold (top right) in the away pos. the truck should have dig enabled and when its towards you it should be "normal" We find its best to run the Mambas with the BEC disabled, simply pull the red wire from the RX harness on each and tape out of the way, don't cut them, and run a RX pack to prevent the Bec's from fighting each other and to provide maximum power to you're servo's This program should work with DX7's and most any other 6+ channel computer radio w/ helicopter programming Last edited by slobin3d; 09-16-2007 at 05:06 PM. |
09-16-2007, 05:16 PM | #2 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
My setup is an A14 mix at 100% programmed to a (elevator dual rate) switch where I can turn the mix on or off. Throttle channel is rear axle throttle Rudder channel is front axle throttle Front steer is ailerons Rear steer is elevator If I want a front dig I just move the throttle stick dead left with the mix on. Tthis drives the front only and the rear drag brake holds things in place. For a rear dig I turn the mix off and move the throttle stick forward. Drag brake on the front holds the front in place and the rear pushes...I can make the truck pivot on a front tire. Both ESCs are programmed for 100% drag brake. Last edited by JasonInAugusta; 09-17-2007 at 03:26 PM. |
09-16-2007, 05:22 PM | #3 |
with my setup you lose the ability to control the rear separately like you can with yours but then you can't use the winch down on the suspension, because the DX6 doesn't have a 3pos switch. plus to move forward and reverse you only have to move one stick instead of 2 in a diagonal. Both methods work, just for me I can't train my finger to operate like that |
09-17-2007, 03:26 PM | #4 |
I'm pretty sure that I could still use of the unused channels for a suspension winch. It'd just entail programming EPAs on that channel for each switch position. When the DX6 is properly configured the way I run you don't need to move the throttle stick in a diagonal to go forward...just move it forward. I've seen several folks get confused on that part of the mix. With the mix on, when I move my throttle stick forward both axles are driven forward. |
01-31-2008, 07:39 AM | #5 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
I run JiA's way and like it a lot. I'll give this a shot too. |
01-31-2008, 11:08 AM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I can tell you how to use the aux and the gear channel to controll a winch in and out......
01-31-2008, 03:19 PM | #7 |
Rock Stacker Join Date: Aug 2007 Location: Canada
Go ahead! I'd like to know...
09-07-2010, 08:48 PM | #8 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
nice info. earmarking this to help with my DX6i moa |
09-08-2010, 08:32 AM | #9 |
I have my dx6 setup to where when i have my mix on both axles go forward with the left up/down stick. My channels are set up to where the left stick is my rear esc and my right stick is my front esc and my front steering. So when the mix is on my rear esc is mixed with front but i still have complete control of the front esc via the right up/down stick so this will allow to cancel out unwanted stalls, also it is easy to dig, while i turn i just push up on the stick and the way i want to turn. Now if i turn off the mix i have complte control of both front (right stick) and rear esc's(left stick). Also when i mentioned earlier that my front esc is till active with the right stick when the mix is on i have it setup on the d/r i think to where i can shut that stick off but doesn't affect the mix, so i'm not accedintally affecting the front esc while i'm turning. Hope this makes sense its kinda hard to explain.
09-08-2010, 08:45 AM | #10 |
RCC Addict Join Date: Jul 2009 Location: Near Boston
| A nice trick
A nice trick i found is that I bound the Rudder (left stick, left/right) to the throttles with two separate mixes. Left runs the front motor forward, and right runs the rear motor forward. This gives you the ability to do front or rear dig and by pushing diagonal you can mix your throttles separately. Example: push stick up at 11 o'clock and you will have 80% front power and 50% rear power. Or if you really want to go crazy push it to 7 o'clock you will have front motor running forward and the rear motor pulling in reverse. This is sick for zero radius turns, but alas it will cost you 1 reverse point :p This is on my DX7, as long as the DX6 gives you the option for 3 mixes this is a breeze. |
09-08-2010, 09:01 AM | #11 |
09-05-2012, 05:32 PM | #12 |
Newbie Join Date: Mar 2008 Location: Allenspark, CO
| Re: DX6 DIG made easier
Ok so reading through this I seem to understand that no one has independent throttle set up everyone is using mixes. All I want is each stick to run the trucks motors independent. The left stick for front motor and front steering servo. And right stick for rear motor and no steering servo for the front. if there is a post on how to do this plz help and show me I may have missread one or two of the post it seems like this may be easy to do but I am have a hard time programming the dx6i that I have. Any help or hints would be very helpfull.
09-05-2012, 05:42 PM | #13 | |
| Re: DX6 DIG made easier Quote:
Plug the front ESC into the channel handled by the left stick. Plug the rear ESC into the channel handled by the right stick. Set both sticks to "full forward" on the travel, EPA's to 100% (if you have them) trims to 0. With the TX on, power up the rig & complete the calibration of the ESC's (you could do one at a time). The ESC's should see "mid travel" as "stopped" and then forward or reverse depending on which way you move the sticks. This is not "dig", but independent control of each motor. BTW, what ESC's do you have?? | |
09-05-2012, 07:05 PM | #14 |
I am using 2 teken fxr's and how is it not dig? The stick in neutral will have the motor full lock up and the other stick Will have power to move rather the front or rear depending on what I would like the truck to do. If that makes sense and thank you I think I might have a chance but if I am wrong about the dig plz tell me
09-05-2012, 07:32 PM | #15 |
Tekin*
09-06-2012, 03:34 AM | #16 |
Rock Crawler Join Date: May 2012 Location: Australia
It's easy if you want independent drive. I've tried driving like this but im hand retarded. I have a mix that I turn on and off depending when I need to. Most of the time I use the one stick, I'm slowly getting better at driving separate. |
09-06-2012, 02:45 PM | #17 |
Ok, good to know hope I can operate it like I think I can but heres to hopeing
