09-16-2007, 06:19 PM | #1 |
Newbie Join Date: Aug 2007 Location: reno
| field programmer?
i recently purchased 2 hitec 5745mg 1/4 scale servos for my super. the front steering servo works like a champ but the rear steer servo sometimes works, sometimes lags, and sometimes tweaks out and goes crazy for a bit. can someone help me with this issue or explain what the hell a required hitec field programmer is?
09-16-2007, 06:29 PM | #2 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
the feild programmer is a $$$ little box that tweeks the settings of you're servo, it can control endpoints, failsafe, speed, centering, all without a computer radio. We had one at the HS I never need to use it though. http://www.hitecrcd.com/servos/show?name=HFP-10 |
09-16-2007, 08:36 PM | #3 |
will that fix the problem of it seeming to not get a signal and all that stuuf?
09-16-2007, 09:18 PM | #4 |
possibly, have you tried just the one servo by its self?? It could be a a number of other problems too, it could be that one of the female connectors inside the plug is loose, it could be a bec issue and that servo just drain more than th others, or you're RX has a bad connection or you're transmitter is working properly
09-16-2007, 11:11 PM | #5 |
i had a bec installed cause my old servos were drainin the batteries. they worked pretty good after that except the fact they they were crap cirrus servos and they just suck. i guess i can take it down to the shop tomorrow or sometime and hev em look at it.
