09-18-2007, 09:45 PM | #1 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
| Perfect Combo ?
Okay, I've been doing some digging and can't find a straight forward answer that I want. So, when time comes to build the crawler that I want there are two things that I want to do with it. Firstly, it will be based off WK axles, and if I have to up their strength, so be be it, but here is what I'm looking for. 1: Be able to crawl up some steep inclines and have all the torque that I need to get up them and over all the boulders in my area. 2: My property is flat and is mainly composed of crushed granite, real loose stuff. So if I want to, I'd like to be able to hammer on the throttle and have some high speed fun in the dirt and weeds. So is there a Motor & ESC combo that I can put together that would give me these abilities? And suggestions and help is greatly appreciated! |
09-18-2007, 09:49 PM | #2 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
Thats a tough combo, the 2 usually dont exist together. maybe one of the novak crawler systems. maybe a RC4WD 2 speed tranny in the mix
09-18-2007, 09:57 PM | #3 |
Well, I was thinking the 2 speed tranny would play a role... and I don't wanna have to switch controllers every time I wanna open up the throttle. What about the Mamba Maxx? Having 2 seperate profiles, one for crawling and then another for speed? |
09-18-2007, 10:00 PM | #4 | |
typically speed motors dont like to crawl and visa versa | |
09-18-2007, 10:04 PM | #5 |
Yah thats true... maybe I'm asking too much then, its a big comprimise one way or the other.
09-18-2007, 10:43 PM | #6 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Hand wound 35t's. And A 3 cell lipo.
09-18-2007, 11:04 PM | #7 | |
Honestly,there's no way to have a set up that'll be great and crawling and speed bashing. There's different set up's that'll pack a mean punch and have plenty of wheel speed for a crawler. Like Jeff's 35t and 3 cell lipo or a 3025-8 outrunner and 10-11 cells. These set up's and a few others would be a bit much for a 2.2 crawler,but it'd be fun none the less. For a speed machine though,they'd suck. IMHO,I think you'd be better off building a good set up for your WK as a crawler with a good amount of torque and wheel speed. Something like a Mamba Max/Crawl master set up from Holmes Hobbies(click the sig or PM JRH's) on a 3 cell lipo. If you want to bash around in the gravels or tear the flower beds up,get you a Stampede or something. There's several little bashers on the market that are cheap to get into and will provide hours of fun. Especially when you apply liberal amounts of HPI"stunt spray" | |
09-18-2007, 11:41 PM | #8 |
raptorman - thanks for the info! I was just talking to a friend and he said that I should look elsewhere for the "speed demon" in me, even suggested an E-Savage or Stampede... so I think I'll have to look into those later and put most of my effor into the crawler first.
09-18-2007, 11:50 PM | #9 |
If you want the ultimate power source,PM JRH's. He's got some great options for crawler electronics. From just enough power to stupid 8mm shaft snapping power,he's got your set up.
09-19-2007, 01:44 PM | #10 |
Quarry Creeper Join Date: Jun 2007 Location: Sacramento
you could always just save your stock WK motor (27T) and use that for bashing and get a 55T-65T motor for crawling. If you solder on bullit conectors to the motor/ESC, changing them should only take a minute or two... OR.... build two trucks! 2x Trucks = 2x the fun, right? |
09-19-2007, 03:45 PM | #11 |
I tried doing this a few years ago. I suggest having two vehicles as well. You can't have a good performing crawler that goes fast too.
09-19-2007, 03:48 PM | #12 |
09-19-2007, 04:16 PM | #13 |
It does have both slow speed control and high top speed, but setting suspension up for great crawling and bashing can be difficult too. I should put one in my WK and see what happens. |
09-19-2007, 04:17 PM | #14 |
09-19-2007, 04:20 PM | #15 | |
Once I get the WK and see where it is performance wise around here before making any decisions. But John seems to be the guy I talk to when time comes. Theres a though! | |
09-19-2007, 04:30 PM | #16 |
09-19-2007, 04:34 PM | #17 |
| I was running the 5 turn on a 3 cell lipo at the nats (not recommended) R2 held up fine. Since the throttle control is so fine, there isn't any jarring or jamming of the tranny as long as the vehicle isn't just driven pedal to the metal.
09-19-2007, 04:44 PM | #18 |
09-19-2007, 04:59 PM | #19 |
I wouldn't trust the current r2 tranny with any motor driven pedal to the metal. You have another one you can use?
09-19-2007, 05:01 PM | #20 |
| Thats what I was running at the nats. IMHO,these are AWESOME little motors. These things have a huge comm and brushes. On top of the cobalt magnets,these things deliver a big level of power with a VERY smooth throttle curve. Didn't seem like overkill power like my 3025-8 but had more than enough to power out of the tightest of binds. The one I was running was a 5 turn 7 pole motor. Being a 5 turn,it would get a bit warm pushing my porky super around. I think it would be better suited for a lighter 2.2. The 7 turn cobalt would probably be better for a super. |
