09-22-2007, 09:25 PM | #1 |
Quarry Creeper Join Date: May 2007 Location: Grass Valley California
| dx 6 or rooster crawler problem
I just bought a dx 6 to run a crawler that I have been using a tq3 and the rooster crawler on with no problems. I am trying to hook up hte dx6 and I can't get netrual to be netrual unless i hold the throttle stick down a little 9 (like i'm trying going into reverse) the same thing happens if I use one of the other controls. i have read through both manuals looking for a clue as to what is going on but I can't figure it out i'm sure i'm missing somthing. Can anyone help me ? Thanks |
09-22-2007, 09:46 PM | #2 |
Program the Radio to the ESC again...
09-22-2007, 10:20 PM | #3 |
That still did not work. When in netraul the red light should be on for the rooster. It does not come on until I pull down on the throttle stick Just a little. I have done this with the motor on as well just to make sure, and it runs until I pull hte stick down. |
09-22-2007, 10:55 PM | #4 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Just go into the progam menu on the dx-6 with the truck on, and adjust the sub trim till it hits neutral on the esc.
09-23-2007, 02:18 PM | #5 |
OK that did it! thanks, I assumed it was some trim but I could not figure out the correct trim imputs the book is not that clear or it could be me ( yea right ) anyway Thanks |
09-23-2007, 04:25 PM | #6 |
No problem, isn't the dx-6 wonderful?
09-23-2007, 10:39 PM | #7 |
So far so good except for the battery usage SU********KS I have charged and drained and recharged a few times now and I can literally watch the meter go down. starts off at 11.6 down to 10.6 is a few min. and so on untill it starts to churp to me maybe 40 min.?? ish maybe 1 hr ish . I have red about the mods but crud for the money one would think one would get more out of it would'nt one ?
09-24-2007, 07:22 PM | #8 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
Time for the reg. mod and a battery pack from Cheapbatterypacks.com
09-24-2007, 07:39 PM | #9 | |
Newbie Join Date: Aug 2007 Location: Chicago
Keep in mind, rechargable batteries are only 1.2 volts per cell. This makes a set of 8 batteries onlt 9.6 volts. When you charge them, they slightly overcharge, showing between 11 and 12 volts, but quickly drop down to the 9.6. Radios with a voltage warning, will chirp at 9.0 volts. What Mah batteries are you using in the Radio? Energizer makes a 2500 Mah, which seems to hold up pretty well. If nothing else, Home Depot usually has a pretty good deal on Dry cell AA's (36 for $11.00) | |
