| | #1 |
| Rock Stacker Join Date: Apr 2005 Location: RC SYNDICATE
| I just needed to know..... I have the "Reverse" motor up front, This is correct right? And....I cant seem to get the mesh no matter how I install this Mag MAyhem with a 9T pinion? Anyone?? |
| Sponsored Links | |
| | #2 |
| Pebble Pounder Join Date: Oct 2004 Location: Colorado
| No, the “reverse” motor goes in the rear, “if” we’re talking about the Clod. If you are using a GD-600, then the reverse would go up front. Take the spacers (“metal tube”) out used on the motor mount screws. That should give enough clearance for proper mesh. Using a rat tail file or Dremel tool will also work. The proper/easier way is to use an adjustable motor mount. http://www.thundertechracing.com/motormnt.htm Read this Sticky: How to build a Clodbuster Rock Crawler |
| Thread Tools | |
| Display Modes | |
