Thread: trinity motor ?
Old 04-24-2005, 10:54 PM   #1
Default trinity motor ?
i have 2 trinity green machine 2's one is marked 2r and the other is not. is the 2r one a reverse rotation? if so do i wire it pos to pos neg to neg from the esc like a normal motor? or do i wire it pos to neg ?
triaxmaster is offline   Reply With Quote
Old 04-25-2005, 08:34 AM   #2
pos to neg
ILoveRCRockCrawlin is offline   Reply With Quote
Old 04-25-2005, 02:56 PM   #3
i might be wrong but if the mtr is reversed already then wire it like normal. if you reverse the wires on a revers motor then your gonna end up runnin the motor in forward and defeat the purpose. let alone prob ruin the motor.
powertuned is offline   Reply With Quote
Old 04-25-2005, 08:46 PM   #4
think i didnt make the Main question clear.
Old 04-25-2005, 09:26 PM   #5
non scientific way to find out. 0 degree spins same rpm fwd or rvrs. advance timed will spin forward faster then revrs= forward rotation. rvrs timed mtr will spin faster rvrs then forward. hook the mtr up and see what happens in fwd and rvrs. should answer your question.
Old 04-25-2005, 09:58 PM   #6
ill try that and see... i thought that reverse motors went backwards of normal not just faster in one direction
Old 04-25-2005, 10:26 PM   #7
hook them both up pos to pos newg to neg and see if it works simple as that and if it doesnt just in solder a wire thats all
firstumustcrawl is offline   Reply With Quote
