10-09-2007, 01:29 PM | #1 |
Newbie Join Date: Oct 2006 Location: owasso
| power issues ?
Ok im just tryin to find out what kind of power to run on my maxx crawler...im goin to run 1/4 scale servos on it so i can get more power for turning...but i im stuck on what kind of power suply to run just for them and what esc to run too so it wont burn up...what do u guys think would work best for my truck?
10-10-2007, 08:42 AM | #2 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
I would run a 11v lipo pack and Castle Creations voltage regulator for each servo. The packs have 12.3v fully charged and the evx will handle it no problem, but the bec is weak at best so that will need help. If you don't wan't to pony up for lipo/ charger and stuff you can always build or have built custom packs with as many cells as your esc can handle! I would still run the Castle reg(s) though. |
10-10-2007, 12:06 PM | #3 |
ok thanks for that info
10-10-2007, 12:15 PM | #4 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
1 castle bec will be more than enough for 2 1/4 scale servos. And if you plan on running a lipo with an evx you will need to install a low voltage cut off for the battery if you plan on using it more than once.
10-10-2007, 04:00 PM | #5 |
im not goin to run lipo cause i have a 3800nmh match pack
