Thread: lathe motor+intellispeed?
Old 04-25-2005, 09:45 PM   #1
Default lathe motor+intellispeed?
I have a duratrax intellispeed (yeah I know it crap but it's all I have) and an integy 55 turn lathe motor. The ESC says it will run an 18-27 turn motor. I know that the lower the turn of a motor the more volts it draws. But it seems that it should run a 55 turn motor. Am I correct? Will it run the lathe motor?
grandkrawler is offline   Reply With Quote
Old 04-25-2005, 09:49 PM   #2
TCS/Holmes Hobbies
SVEN's Avatar
Yes it will run the lathe, I don't know of any esc that cannot run a lathe motor.
SVEN is offline   Reply With Quote
Old 04-26-2005, 12:13 PM   #3
I'm using the same setup,, no problems
Thommy2Tone is offline   Reply With Quote
