07-20-2005, 01:53 PM | #41 | |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
I think there's only so much you can do with a pistol grip radio. I mean modding my TQ3 was a great way to kill time but if I was going to compete I'd probably just use a dual stick radio like my Futaba 9C. There's just way more flexibility and granularity of control with a good 2 stick radio. | |
07-20-2005, 02:40 PM | #42 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
thats cool...im thinkin of going rear steering....DOH thats another 40 dollar servo and a 20 dollar radio... w/e... where did you buy your Tq3?
07-20-2005, 02:43 PM | #43 | |
07-20-2005, 02:44 PM | #44 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
The crawler store has them with the indipendant rear steer already installed for 65 bucks.Thats pretty cheap
07-20-2005, 02:56 PM | #45 |
hmm lets c here 15 bucks of 65... 15$ one is stock no 'good' switch...price for swithces and pots MAX of 10 bucks 65$ come with 2 dollar switch ... I wonder which one i could buy for cheaper... LOL just playin man. Hey FritoBandito Could you not just put a little on off switch that leads to the cener wire if i were to use a pot instead of a switch to center it or would i need to switch on and off the 2 outter wires? i wish my friggin Jr X3i had the ability of doing a 3 position 3rd chanel... all it has is 2 position like for reverse on a tmax or some stupid fule mixture servo function... AND IT HAS THE FREAKING SWITCHES ON THE THING TO DO 3 positions... I could always mix the chanels... but then i wouldnt have independent steering... Last edited by nd4spdbh; 07-20-2005 at 03:02 PM. |
07-20-2005, 06:36 PM | #46 | ||
07-20-2005, 06:54 PM | #47 |
ya but i want sort of a lock out switchs that when i switch it on it centers the steering but when i turn it off i can use the pot to steer the rear end. Oh and are the stock pots for the trim settings (throttle and steering) are the 5k ohms? I was thinking of doing something like a scroll wheel on a mouse for the rear steering in the tumb area of the TQ3 and then have a little centering/lockout switch above that. i am soo doing this i have 2 Regular TQ radios that i can rape parts off of. and for freakin like 25 bucks shipped to my door i have a perfect 3 chanel radio... instead of a 140 dollar pos that only has channel mixing instead of independent steering... Last edited by nd4spdbh; 07-20-2005 at 06:56 PM. |
07-20-2005, 07:04 PM | #48 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
i got to thank you for this info i was trying to figure how to do this to my airtronics 3p.after mj6 i'll get the switches and fix it up. as for the pot for steering is combersome at best.it doesn't center itselfe and you have to look at it to center it.and to turn it is combersome.the 3p had a pot type switch orig and i left it in the curcuit so if need be in a rush of seting up a rear servo i can use it to center the servo and use the momentary switch to turn.pitfall of doing this of coarse is that the servo will not turn the wheel the same distance left to right.but with the trim buttons that should be solved.my next problem is to find a place on my radio to mount the 2 pot switches.not much room |
07-20-2005, 07:05 PM | #49 |
I see what you're saying. Then yea, a switch (with a cap) on the center wire would do the trick. The stock steering pot is a 5K. The trim pots are 100k. What are you thinking of doing with the trim? |
07-20-2005, 07:14 PM | #50 | |
07-20-2005, 07:33 PM | #51 |
i was thinkin of using the trim pots for a rear steering type of mini steering wheel but as u said they are 100k instead of 5k... lol i should have taken apart my TQ b 4 i went asking ...they have it printed right on it Doh. n e ways. I am still debating on wether i should go with a 3p switch or a pot with a centering switch... hmmm I just love the idea of a todally independent proportional rear steering... AHH mabey i could mount a throttle assembly from one of my other tq radios... OOO Last edited by nd4spdbh; 07-20-2005 at 07:36 PM. |
07-20-2005, 08:06 PM | #52 |
some one on this board did this at one time,he used a steering wheel for the 3rd channel so there was 2 steering wheels on the tq3.sorry,i don;t remember the members name.
07-20-2005, 09:15 PM | #53 |
well i could also do that it would be quite intresting tho... lol
07-20-2005, 09:31 PM | #54 |
OK FritoBandito I was thinkin of doing a momentary switch on the center wire to a pot controling the rear steering. the momentary would be placed in a position where i could get my middle or ring finger to be able to push it. SO when im not pushing it the rear will center up then when i want to steer in the rear i would just hold the little button down... would that work? Also would these pots work? Main steering pot : http://www.radioshack.com/product.as...Fid=271%2D1714 EPA : http://www.radioshack.com/product.as...5Fid=271%2D280 I kno the EPA pots that i posted are not up there in k ohms they are only 1 k ohms. Also they are only rated for .1 w at 50 v dc... but thats 50 volts... |
07-20-2005, 10:08 PM | #55 | |
07-20-2005, 10:29 PM | #56 |
sry not a momentary switch sort of like a push button switch. so when i let up on it it would cut the circut centering the servo.
07-20-2005, 10:30 PM | #57 |
hey Fritto, For your third channel,is that one of the push forward,and when you let it go,it will spring back to center?If so,where did you get that?I need one of those,this switch is killing my thumb! |
07-20-2005, 10:44 PM | #58 | |
Dude, go with whatever makes you happy but I think you're going to find your control method difficult to use. I think the coordination of front steering, throttle with index finger, pushing a button with your ring finger, and working the rear steer with your thumb is going to be a *****. Also, the switch does provide for immediate centering but you're only putting off the inevitable task of manually relocating center. I actually think it would be better to leave the rear steer on all the time and just get into the habit of recentering the rear as you use it. I was thinking about it and I think you might consider using an audio taper pot around the 7k value. That would let you have a shorter throw on the rear steering making it easier on your thumb and since it's an audio taper it would still have very a very fine control. Something to think on. | |
07-20-2005, 10:51 PM | #59 | |
Next time I do some project like this I'll have to remember to document all the parts so I don't look like an idiot later. Oh well. | |
07-20-2005, 10:53 PM | #60 |
Its ok..I might stop by there maybe on friday,since we are gunnabe there..What should I ask for?Momantery switches?I might pick up some mini computer fans,as well..They hook it up!They sold me one for 2 bucks last time I was there.
