01-04-2006, 03:30 AM | #101 |
Quarry Creeper Join Date: Nov 2005 Location: fairfax
this thread ROCKS!!!8-) with all the pics and diagrams i was able to easily do my own conversion. THANX everyone |
01-04-2006, 03:32 AM | #102 |
last two
01-04-2006, 09:07 AM | #103 |
Pebble Pounder Join Date: Sep 2005 Location: Canada
why did you put the switch on the top?
01-04-2006, 05:17 PM | #104 |
i drive the wheel with my left hand (duh...i know) and would straddle that switch in between the thumb and forefinger. i thought it would be easy to just hit the switch with a little twist of the wrist. i may have to move it if the action isn't as smooth as i think it will be. i also thought of moving it down the side in front of the wheel. that way i could just flip it with the fingers i'm not using on the wheel. |
01-14-2006, 06:10 PM | #105 |
RCC Addict Join Date: Dec 2004 Location: Central NY
I got a few questions. First off; will 1k pots work? I went out and bout 2 for doing the indi steer. Another question is if I wanted an on/off switch for the rear steer, how would I wire that in, and would it center out if I were to do that? And is there a 'lil more detailed wiring diagram somewhere? Last edited by ILoveRCRockCrawlin; 01-14-2006 at 06:14 PM. |
02-09-2006, 04:37 PM | #106 |
Newbie Join Date: Dec 2005 Location: hungary
hi, i went through these tq3 topics, but couldnt find any info how could i mix ch1 and ch3 with a switch. maybe because of my language barrier / im from hungary / , i picked up a tq3 for this reason, but found out that with stock settings it cant be done i think it would be hard to me to controll the rear wheels independantly, i would prefer them to move together with the front wheels i apologise if i posted this in a wrong topic |
02-09-2006, 06:18 PM | #107 | |
Pebble Pounder Join Date: Apr 2005 Location: Torrance, CA
02-09-2006, 07:59 PM | #108 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
Yup... a Splitter pluss a reverser will do you just fine... But i think you will be alot happier with indepented rear wheel steering. I was leery at first and it took me all of about 2 batteries to get how to use it. Plus you realize the pluses with it. Also if you wanted to mod ur controler to mix the 2 channels you would have to do some crazy circuitry... overly complicated and useless. Ben (Sup FritoBandito) |
02-09-2006, 08:15 PM | #109 |
cant you just have a switch, when on, channel 3 will use the front steering pot (hence mixes the two channels), when off, it switches to the rear steering pot?
02-09-2006, 08:19 PM | #110 | |
02-09-2006, 08:35 PM | #111 |
I think it would work on the transmitter itself. Ill try it when Ill have some time on my hand.
02-10-2006, 07:23 AM | #112 |
you could.... but then you got to factor in when you put 2 channels on one pot u have to increase the ohm rating by 2.... so instead of a 5k you would need a 10k for 2 channels and then when you switch off you need a5k pot.
02-10-2006, 12:51 PM | #113 |
you would only increase the current, because the two channels are parallel. the voltage would remain the same. The ohm rating of the pot only determines the end points of that channel (lower resistance means less travel) because it acts as a voltage divider, and the signal transmitted is proportional to these two voltages and their difference between the trim pot.
02-14-2006, 02:02 PM | #114 |
Quarry Creeper Join Date: Nov 2005 Location: LBC
Has anyone found any sort of self-centering pot with a knob to use in place of the 3 position switch to provide proportional independent rear steering instead of the full left/center/full right? I've been digging around on the net but haven't found anything yet. Lots of pots have knobs, but I can't find anything that is self-centering.
02-18-2006, 12:33 PM | #115 |
you will just have to get used to centering them.
02-18-2006, 08:49 PM | #116 |
I'm on it. it will take me a little while to find all the parts I need and get everything operating properly, but I've figured out a couple of different methods that might prove to work well. I'll report back when I have pics and something to show. I'm juggling too many projects right now like an idiot. I always end up doing that |
02-19-2006, 01:54 PM | #117 |
hi thanks for everyhing, i got used to with the 3way switch in 20min, works excellent |
02-25-2006, 10:19 PM | #118 |
Rock Stacker Join Date: Feb 2006 Location: Grand Junction
Well I just found out that 1k pots just do not adjust the end points enough for the hitec 5955 digital servos. Rat shack doesn't have any 2.5k or higher submini pots! grrrrr. I must say though, this thread saved me some bling before I was gonna throw money away on another transmitter. This radio works actually quite well this way. I installed the front and rear steering epa pots. Once again, everything was easy to do except fit all the dang wires in there! grrrrrr. People, if you haven't done this mod yet, take special notice of wires and their routes, etc..... Real estate is at a premium in this transmitter. |
02-27-2006, 02:05 PM | #119 |
Rock Stacker Join Date: May 2005 Location: hills
"cosmohi, i went through these tq3 topics, but couldnt find any info how could i mix ch1 and ch3 with a switch. maybe because of my language barrier / im from hungary / , i picked up a tq3 for this reason, but found out that with stock settings it cant be done i think it would be hard to me to controll the rear wheels independantly, i would prefer them to move together with the front wheels i apologise if i posted this in a wrong topic" 1: cosmo these type y harnesses are commenly used on airplanes to work the flaps.mine is horizon hobby y harness reverser standard.item# #exra320.horizonhobby.com .but if your controler doesnt have servo speed adj. it is realy weird to drive...turns to fast. 2:question,can you wire the pot between the servo and rx in the truck?or does it have to be at the switch in the controller?just a thought,if it works you wouldnt have the space problem as with the controler.sorry if this was covered and i missed it,but i didnt see anything. |
05-03-2006, 02:58 PM | #120 | |
Rock Crawler Join Date: Jan 2006 Location: Dallas
