Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: Team Associated teasing a scale crawler!
Old 08-03-2019, 10:03 AM   #681
Default Team Associated teasing a scale crawler!
Originally Posted by SensibleChuckle View Post
I just got mine, but I can't seem to find the power switch on the truck. The moment I pop the battery in it starts up. Do they come with one on the receiver or is this standard?
If there’s a switch it would be on the ESC, but not all ESCs use switches.
I got the kit so I’m not sure what the RTR has.
EDIT: https://img2.associatedelectrics.com..._Manual_OL.pdf
HumboldtEF is offline   Reply With Quote
Old 08-03-2019, 10:10 AM   #682
Default Re: Team Associated teasing a scale crawler!
All in the first line in the manual.......
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 08-03-2019, 10:36 AM   #683
Actually seems like Associated paid attention to everyone bitching about failed switches!
durok is offline   Reply With Quote
Old 08-03-2019, 11:43 AM   #684
Yep, no switch. I got a HW1080 for the power switch and jack-rabbit reverse, but switching motor leads fixed the latter. So its still in the box.
Browneye is offline   Reply With Quote
Old 08-03-2019, 07:01 PM   #685
So I got to maiden my Enduro yesterday. It lasted all of 30 seconds before the axle housing broke. One of the screws that holds in the bearings broke out of it's threaded hole
Unfortunately the hard axle housings weren't available when I ordered my kit, but I've got them on the way now. What a disappointing first day. Good thing I took a couple more rigs with me. Anyway, here she is...
punkindrublik is offline   Reply With Quote
Old 08-03-2019, 08:00 PM   #686
That's a bummer!
I trimmed the Lexan bedliner for the utility bed, sanded the edges smooth - need to put the body post holes and mounting screw holes in it tomorrow and test fit it.
I'll be painting it soon... and am still thinking about how to paint up the RTR cab body.
It's really thin, might not last that long - so I may be doing something beater-ish...
So far, keeping it very light - the only added weight is Element 6mm steel hexes, and SSD steel wheels.
Instead of a steel front bumper I got from RC4WD, I decided to stick with soze's idea of the GMade BOM plastic bumper - it really matches the utility bed well - tubes are looking the same diameter...
Old 09-12-2019, 04:52 PM   #687
Does anyone know what the ground clearance is for a stock RTR Enduro at the skid? Thanks
Sent from my LM-G710VM using Tapatalk
MaX-D is offline   Reply With Quote
Old 01-07-2020, 10:19 AM   #688
Originally Posted by durok View Post
That's a bummer!
Which wheels and tires are these?
Wisceaux is offline   Reply With Quote
Old 01-07-2020, 12:25 PM   #689
SSD 1.9 Steelie 5-slots, RC4WD 1.7" Interco Boggers (pre-siped)...
Old 01-07-2020, 04:11 PM   #690
super noob here... just got my first crawler, the RTR senduro. ran it for a bit today. what do ya'll do to keep the tires from rubbing the fenders?!?
thanks!!
b_mock is offline   Reply With Quote
Old 01-07-2020, 04:38 PM   #691
thanks!!
Cut the fenders.
soze is offline   Reply With Quote
Old 01-07-2020, 05:00 PM   #692
Originally Posted by soze View Post
Cut the fenders.
right on... you cut them completely off or just trim them back a bit?
Old 01-07-2020, 07:03 PM   #693
Entirely up to you. I just trimmed mine a bit so that it wouldn't get caught.
Eventually though... I tumbled off cliffs enough for the one of them to fall right off!
Perfect break separation!
Needless to say, rather than running with one fender gone and one fender on... I cut the other one off.
Old 01-07-2020, 07:45 PM   #694
Did a bit of both on mine. Completely cut of the tears and trimmed the fronts.
Was in a bit of a rush and need to go back with some sandpaper to clean the fronts up.
jason02ws6 is offline   Reply With Quote
Old 01-07-2020, 08:08 PM   #695
One thing I like to do around areas like that is pickup some Shoe Goo and sticky drywall tape.
- Apply tape
- Paint over it with the Shoe Goo
Makes a body pretty well bullet proof.
Xx Losungen xX is offline   Reply With Quote
Old 01-08-2020, 11:53 AM   #696
hahaha.... ok think i may just trim a tiny bit off as im super noobish. im afraid to do to much. just dont really like the sound of the plastic rubbing. i dont feel like it hindered the performance really.. thanks again!
Old 01-08-2020, 11:55 AM   #697
you guys just using scissors, exacto knifes? what works best?! thanks!
Old 01-08-2020, 11:57 AM   #698
I use Duratrax lexan scissors. I have had the set for years and they work really well. I would assume any scissors would work but I prefer the angled pair personally.
https://www.duratrax.com/accessories.../dtxr1150.html
Old 01-08-2020, 11:59 AM   #699
Same here.
Old 01-08-2020, 02:59 PM   #700
I use a set of Kyosho KRF curved lexan cutting scissors that I've had for over 30 years. That's not a typo, I purchased them to cut out bodies for my Kyosho Ultima back in 1989. I just used them 2 nights ago to trim out the rear bumper on my Enduro Trailwalker. Once I decide on what size of tire to run I'll trim my fenders.
colbynobo is offline   Reply With Quote
Team Associated teasing a scale crawler! - Similar Threads
Team FastEddy Team Losi 1/10th scale crawler Bearing Kit FastEddy Team Losi Comp Crawler 12 04-16-2012 04:31 PM
Just teasing..... Erik D_lux Team Losi Comp Crawler 7 11-14-2010 06:59 PM
Team Losi Crawler 1/18 Scale NEW RPP Hobby RPP Hobby 22 08-31-2008 08:35 PM
