07-10-2019, 02:21 PM | #41 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: What I'm doing to my ENDURO! |
07-10-2019, 02:35 PM | #42 |
Just got this in the mail, My kit is on its way!!! Order Comments: 6/7/19 - customer request change to ASC40102 (kit) - store credit issued for difference. DS 5/20/19 - ASC40100 - PRE-ORDER - will ship when available. DS Your items shipped on 07/10/2019 via USPS : Priority Mail 3-Day™ TRACK YOUR PACKAGE with tracking Items Ordered: Price: Status: 1 of : Element RC Enduro Trail Truck Builder's Kit $239.99 Shipped 1 of : Store Credit ($110.00) Type: To: Ernie Ledbetter From: RPP Hobby Message: store credit for revised order Send To: ledspots@yahoo.com $0.00 Shipped |
07-10-2019, 02:43 PM | #43 |
Quarry Creeper Join Date: May 2013 Location: no-water-no-trees-country
07-10-2019, 02:51 PM | #44 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
07-10-2019, 03:31 PM | #45 |
Hope to see some Friday, mine will be here Monday, my UPS guy is here at 4:30 usually!! Hang up and Drive |
07-11-2019, 11:02 AM | #46 | |
| Re: What I'm doing to my ENDURO! Quote:
Ernie | |
07-12-2019, 12:12 PM | #47 |
This is as clean as my shop usually gets, and the last time you will see this clean for a while! And the closest thing you will see to a unboxing from me. (they are not one of my favorites! No step by step either, I will show a few pics and answer questions, besides you all already know what they look like put together!!! Let the building begin!!! Ernie |
07-12-2019, 12:18 PM | #48 |
Confirmed, plastic ball!!!
07-12-2019, 03:00 PM | #49 |
Show the shocks, no one wants to !!! Hang up and Drive |
07-12-2019, 03:18 PM | #50 |
Nice Ernie! My kit just showed up as well. I stayed up super late cleaning up my workbench in anticipation which is a rare occurrence (the cleaning up part, not staying up late) lol . I might just start with the shocks Mike, I'm curious too. |
07-12-2019, 04:46 PM | #51 |
07-12-2019, 04:54 PM | #52 |
Nice, I can't wait to see what you do!
07-12-2019, 05:05 PM | #53 |
It’s nice to see the kits are finally starting to arrive. Can’t wait to see these kits and how they compare to the RTR. Looking forward to seeing all the different builds everyone will be doing. Sent from my iPad using Tapatalk |
07-12-2019, 07:21 PM | #54 |
07-12-2019, 09:51 PM | #55 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Looks like some good AE quality!
07-13-2019, 06:43 AM | #56 |
Beautiful! Loaded question, how do they stack up against the dravtechs ? Hang up and Drive |
07-13-2019, 10:45 AM | #57 | |
Ernie Consider that my like button! Out to the shop in a few! Ernie | |
07-13-2019, 11:22 AM | #58 |
Well I’m a big bore fanboy, proudly, as you say they work, and don’t leak. My take on these is a step up from dravtech/ big bore because of the threaded preload, vs o rings etc. these are pricy if you build them up from parts the kit shocks are $70.00 plus a pair! Dravtechs are $37.00 pr These were the real reason along with gears for doing the kit. Thanks for the review! Hang up and Drive |
07-13-2019, 01:20 PM | #59 |
I assembled the shocks too, they feel really nice and smooth (30 wt oil). I heard people saying these leak so I took measurements on the O-rings and spacers before I completed the last one in case that does happen. This way I can look into making up a thicker spacer or O-ring if they do leak. The preload adjusters have a groove for O-rings to keep them from moving which is a nice touch. I did notice that the hole on the main shock body for the shock shaft is larger than I'm used to seeing. I was thinking it should be tighter to keep the shaft true and stable, but after assembling them they are nice and stable. This is probably due to the thicker than usual spacer between the O-rings, which puts the O-ring farther apart. Since the shaft rides on these O-rings the farther these are apart the better (more stable/less deflection). I also went a bit overboard (might have imbibed too much of the koolaid at the time) and got their bronze shock bodies and black top and bottom caps. Then I realized with just a few more parts I could have 2 sets, ordered more parts Anyway I really like the look of the bronze shocks I also installed some of the softer springs, the white and green which feel good, nice and soft. EDIT: also worth noting the spring perches fitment on the rod end is very very tight, you really need to press them on quite hard to get them fully seated. Removing them takes a lot of force or tools which is unfortunate (might be easier to unscrew the rod end) but at least these wont be falling off and getting lost. @CODYBOY some of yours spring perches look fully seated and some look like they might not be, as I mentioned it takes a fair bit of force. Also worth noting, the chassis with the hard parts is very stiff and rigid Last edited by HumboldtEF; 07-13-2019 at 01:34 PM. |
07-13-2019, 01:57 PM | #60 | ||
The Dravtechs are expensive, but IMO you get what you pay for. Quote:
Casey, if I ever had a business I'd want you for my Quality control!!!! Good job young man! I notice the one shock in my pics last night. Just a little caveat when building your shocks. When your bleeding them make sure you lube the o-ring at the top of the shock body, it is really easy to have it pinch out when tightening the shock cap. When I get the cap turned down to the o-ring I twist the cap a little both ways to be sure the ring is captured into the cap. It would be really easy to tear the rubber and ruin it. On to the axles, I had these Yeah Racing chubs in my stock and so I thought I would try them. Went on and tightened up very nice on the stock (hard) axle. They are just a little tighter than the SSD chubs and I don't they will come loose. I also clearance the unis for a few more degrees of steering. And the rear is done too. All for now guys, maybe more later today. Ernie | ||
What I'm doing to my ENDURO! - Similar Threads | ||||
kmc enduro? | flat out | Tires and Wheels | 18 | 11-18-2012 10:59 AM |
The 1/8 Wonder Enduro Race | The Cow | Non Crawler RC's | 5 | 09-22-2010 03:47 PM |
2.2 enduro-courser | rmdesignworks | Non Crawler RC's | 6 | 12-04-2009 06:00 PM |
Enduro Cross | twisted | Chit Chat | 7 | 02-05-2008 08:22 PM |
