Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: What I'm doing to my ENDURO!
Old 07-16-2019, 10:01 PM   #81
Default Re: What I'm doing to my ENDURO!
Next time use a katana, it will fit better!
But seriously thats rad and cant wait to see where this is going!
Shinchu is offline   Reply With Quote
Old 07-17-2019, 12:05 AM   #82
With that body cut like that.. you're going to be super light with a lot of body clearance!
soze is offline   Reply With Quote
Old 07-17-2019, 12:10 AM   #83
The bikini of crawler bods...
punkindrublik is offline   Reply With Quote
Old 07-18-2019, 12:12 AM   #84
That Jimny Enduro looks promising
After a lot of messuring, cutting, fitting, cutting again, thats how it looks now. I am really happy how it turned out.
There is still a lot to do, but I like how the cage sits and that I could use the whole bed.
Gesendet von meinem TA-1004 mit Tapatalk
GrimmTheTourist is offline   Reply With Quote
Old 10-30-2019, 04:13 AM   #85
Originally Posted by B-MOW71 View Post
Body reinforcement! Added Gorilla tape and rounded the slots where the sliders run through the sides of the body. Put tape under each body mount hole to tighten it up when the clips are attached. Also added bolts to secure bed to cab.
Doing this stiffened the body up and does not rattle like it did. It’s solid now!
Attachment 382106
Attachment 382107
Attachment 382108
I like the Gorilla tape idea!
Cesco is offline   Reply With Quote
Old 10-30-2019, 04:19 AM   #86
Originally Posted by HumboldtEF View Post
Anyway I really like the look of the bronze shocks
Love the look of those shock in this color combination!
Old 10-30-2019, 06:05 AM   #87
Go Buckeyes!
B-MOW71's Avatar
It works great! I use it on all of my lexan bodies.
B-MOW71 is offline   Reply With Quote
Old 03-17-2020, 04:54 PM   #88
Threw on proline xj body Got my ripsaws unmounted from the glue on wheels an onto the Sendero beadlocks. Much better cog now, also did rear shock/link mount mod and rear upper link risers. Besides 11.xx% od that's all I've done to it, and wow it goes almost anywhere!
biev is offline   Reply With Quote
Old 03-18-2020, 09:44 AM   #89
I built it and it’s currently sitting as a slider with ifs, servo and motor. Will be using mock up tires tonight and cutting the body
c0bra is offline   Reply With Quote
Old 03-18-2020, 10:04 AM   #90
Put some shrink rc body mounts and went from the trailwalker to this
djr01974 is offline   Reply With Quote
Old 03-25-2020, 09:40 PM   #91
Well can’t leave well enough alone. Ordered some rear links from associated and shortened the wheel base to 11.8. After I measured it is actually 11.5. Install the bed on the cab and fits really good. The Tamiya hilux clone body and bed works out ok. I didn’t need to cut the bed to fit the shock towers. Lays perfectly flat I also have the front and rear lights in it. Still using the trailwalker bumper. I’m thinking I like this better than the cage. Be safe everybody
Old 03-27-2020, 08:18 PM   #92
Painted up the interior and raised the front ride height a bit.
Old 03-28-2020, 09:58 AM   #93
Go Buckeyes!
B-MOW71's Avatar
Great looking truck!
Do you have a build thread or pics of how the body mounts look?
Old 03-28-2020, 10:27 PM   #94
Thanks. I do not have a build thread. But the body mounts are from shrink rc. I’ve attached the link and posted a picture for you. I’m using the hilux body which works out good because the bed isn’t deep like the RC4WD bed which you have to cut to accommodate the shock towers. Hope this helps.
https://rover.ebay.com/rover/0/0/0?m...2F402096316071
Old 03-28-2020, 10:40 PM   #95
Attachment 388089
You should start a build thread Dave. You've got enough content now!
Old 03-29-2020, 11:23 AM   #96
Go Buckeyes!
B-MOW71's Avatar
Thanks for the info!
The Shrink RC mounts look nice. I'm glad to see that you are still able to use the larger battery tray.
Old 03-29-2020, 02:08 PM   #97
Yeah I have too many full size batteries and did t want to start buying shorty packs. Anything over 5200 mah won’t fit with the interior. I painted up the factory trailwalker wheels and put the little tires on for a bit. Looks ok. Name:  AD3BF186-464B-45E0-BB4C-0F3BE8D515F8.jpg
Old 03-29-2020, 05:49 PM   #98
So because we can’t really go anywhere and practicing social distancing so this virus will hopefully go away I decided to work on the element/ Yota again. So I fount a place to mount the waterproof receiver box so I can put the receiver and my light controller in just in case. I don’t normally run in water but a little piece of mind.i did have to trim the bed. I need some gas cans now. ��
Old 04-10-2020, 08:37 PM   #99
So I picked up an axial blazer bumper , trimmed the bed and than I needed to drill some new holes to suck the bumper in some. Than I pained up my shell from the bruiser and mounted it. Name:  4D1C2F30-502D-41DB-AAE1-F38902AD3EB1.jpg
What I'm doing to my ENDURO! - Similar Threads
kmc enduro? flat out Tires and Wheels 18 11-18-2012 10:59 AM
The 1/8 Wonder Enduro Race The Cow Non Crawler RC's 5 09-22-2010 03:47 PM
2.2 enduro-courser rmdesignworks Non Crawler RC's 6 12-04-2009 06:00 PM
Enduro Cross twisted Chit Chat 7 02-05-2008 08:22 PM
