07-12-2019, 06:08 PM | #81 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: New Associated Enduro Crawler - Free-Mods & Upgrades
Here's a couple from me. Modified CBE link brackets and short Revo ends to gain some anti-squat. And a recycled Axial battery plate on the sliders.
07-13-2019, 09:34 AM | #82 |
Rock Stacker Join Date: Feb 2018 Location: United States
I was fabbing up link risers that are almost identical. Have you ran the truck with them? Sent from my iPhone using Tapatalk |
07-13-2019, 04:50 PM | #83 |
Yes, today. I have the links at the lowest position on the bracket, but plan to move them up another hole. I tried a line that I failed at before and it has made a difference. One more hole up and I think it'll be dialed. This is just a random picture from today.
07-13-2019, 05:01 PM | #84 |
The link risers can also be mounted to the outside of the chassis, but you'll need to clearance the side plates. Both ways achieve the same results.
07-13-2019, 06:28 PM | #85 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Might have me some aluminum stock and a hand full of Jato rod ends... Hmmm... Nice quick little mod that should make a noticeable increase for very little dollars. Thanks! |
07-13-2019, 07:36 PM | #86 |
The CBE risers I used had to be placed further back on the chassis to clear the motor and skid. The short upper rod ends brought the axle back to a stock position. You may have an easier time with your own custom made brackets. I used what I had on hand. Definitely worth the small effort.
07-13-2019, 10:45 PM | #87 |
And after looking at sozes work with a BOM rear cage, I might make my own upper shock hoops too...? Great stuff!!! |
07-13-2019, 11:30 PM | #88 |
| Re: New Associated Enduro Crawler - Free-Mods & Upgrades |
07-14-2019, 01:08 AM | #89 |
Rock Crawler Join Date: Jul 2016 Location: Southern Oregon
Revised Cab/Bed brackets: https://www.myminifactory.com/object/3d-print-96751 Requires drilling 2 new holes, as well as 2 extra screws. Reduces the Cab/Bed flex a fair amount. Doesn't eliminate it, but it helps... |
07-14-2019, 10:50 AM | #90 |
Oh those are great! I was thinking something like that would be a good fix, and there it is! Now I just need to decide on keeping the bed, or removing it for a BOM cage like soze has shown us, or going with an entirely different body?! These are good problems lol |
07-14-2019, 01:26 PM | #91 | |
| Re: New Associated Enduro Crawler - Free-Mods & Upgrades Quote:
I really like the BOM cage on this chassis. Using the BOM body would've made it fit even better... but I already have an actual BOM lol. Anyway, I have a SR5 cab I can use as well, but I really like the Enduro cab with the hard plastic detail parts. All I need to do is stiffen up the rear suspension, and extend the rear cage posts. I had a chance to run it with the cage and it did pretty well despite the rear shock position. | |
07-14-2019, 01:26 PM | #92 |
RCC Addict Join Date: Sep 2017 Location: The OC
Pretty cool truggy there... |
07-14-2019, 01:48 PM | #93 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Like, haven't seen you on here much lately! Ernie | |
07-14-2019, 02:20 PM | #94 | |
| Re: New Associated Enduro Crawler - Free-Mods & Upgrades Quote: | |
07-14-2019, 02:34 PM | #95 |
07-14-2019, 03:41 PM | #96 | |
That's to bad! any chance of it starting up again? We need to get together for coffee next time we are down Medford way. Ernie | |
07-14-2019, 04:59 PM | #97 | |
Sent from my SM-G970U using Tapatalk | |
07-15-2019, 12:34 PM | #98 |
I was looking at the battery tray thinking it could sit lower so I did a bit of tinkering and came up with this: Lowered battery tray, the battery is as low as it can go in the stock location now. Its basically sitting on the frame rails now. What I did was notch the stock battery tray for the chassis rails. I used the ridges next to the holes as a guide of where to cut and the battery strap notch for the other cuts, and the angle I did freehand with a razor. The other cuts were made with a fine toothed hand saw. Flip the battery tray mount point/crossmember upside down so its offset downwards instead of up. Notch the battery tray to clear the driveshaft. Removed the ridge that runs between these holes so the battery tray could sit on the mount (this is probably not needed as I did shim this up a bit after) With all that the tray now sits like so, with the chassis rails sticking up a few mm. I printed up some spacers to lift the tray up 2.3mm Put them in these holes and that raises the battery tray up so its now flush with the chassis rails. Stock screws can be re-used. I though about designing a new tray to 3D print but hey why not re-use what I already have. Last edited by HumboldtEF; 07-15-2019 at 12:43 PM. |
07-15-2019, 01:42 PM | #99 |
VERY nice! my battery is just barely too big (currently not sitting flush in my enduro), so i might try the extra ascender battery tray i have laying around as my batt fits in those perfectly. this is great, maybe i will buy slightly smaller 3S packs and do this. |
07-15-2019, 02:11 PM | #100 |
That mod should work with the larger tray too I assume. I think the RTR included the big and small battery tray too right?
New Associated Enduro Crawler - Free-Mods & Upgrades - Similar Threads | ||||
Parts & Upgrades for Element RC Enduro - In Stock! | RPP Hobby | RPP Hobby | 0 | 06-25-2019 09:37 AM |
Coming Soon - New Parts & Upgrades for Element RC Enduro | RPP Hobby | RPP Hobby | 0 | 05-24-2019 04:19 PM |
REDCAT GEN 8 SCOUT 2 | MODS & UPGRADES tips & tricks ANYONE CAN DO! | shenlonco | Redcat Crawlers | 2 | 01-21-2019 04:52 PM |
Upgrades & mods to my JK rtr, good or bad? | axial 4x4 crawler | Axial SCX-10 | 5 | 01-14-2014 01:44 PM |
