Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: New Associated Enduro Crawler - Free-Mods & Upgrades
Old 07-31-2019, 05:37 AM   #161
Default Re: New Associated Enduro Crawler - Free-Mods & Upgrades
I thought SORCA rules required a frame-mounted servo.
Browneye is offline   Reply With Quote
Old 07-31-2019, 11:01 AM   #162
I think the on-axle servo mount was released purely to provide an option for custom builds using the Element axles...
Not an uninteresting idea given the "hard" versions of the housings being so cheap...
durok is offline   Reply With Quote
Old 07-31-2019, 08:00 PM   #163
If anyone's been waiting on the brass or aluminum wheel hex's AE has them in stock finally
https://www.associatedelectrics.com/...dapters_brass/
https://www.associatedelectrics.com/...ters_aluminum/
HumboldtEF is offline   Reply With Quote
Old 07-31-2019, 09:14 PM   #164
Originally Posted by durok View Post
I saw on-axle servo mounts in both plastic and metal over on ShapeWays for the axles today... and a metal one-piece shock hoop and Panhard mount.
Also, front inner fenders that seem to include battery supports for bigger batteries.
Hot Racing brass wheel weights advertised as specific for the Enduro on fleaBay.
Stuff is coming out!
My Elem-End-Ero shipped yesterday... (shortened the name a bit, too dang wordy)
Any chance you could throw some links up for us to click and drool?
And thanks for the update on the wheel hex adapters! Been debating on those or SSD drum brakes.
Shinchu is offline   Reply With Quote
Old 08-01-2019, 03:42 AM   #165
Panhard/shock tower - steel:
https://www.shapeways.com/product/JP...li=marketplace
Inner fender left front:
https://www.shapeways.com/product/RP...li=marketplace
Inner fender right front:
https://www.shapeways.com/product/EY...li=marketplace
On Axle Servo Mount in steel - same vendor for plastic:
https://www.shapeways.com/product/3A...li=marketplace
Steel lower link mounts:
https://www.shapeways.com/product/44...li=marketplace
Rear chassis brace:
https://www.shapeways.com/product/WK...li=marketplace
Twin-tube rear roll bar:
https://www.shapeways.com/product/CK...li=marketplace
Wiring fix:
https://www.shapeways.com/product/5J...li=marketplace
Servo brush guard:
https://www.shapeways.com/product/5H...li=marketplace
Roof rack:
https://www.shapeways.com/product/XU...li=marketplace
Grille:
https://www.shapeways.com/product/7S...li=marketplace
Body clamp:
https://www.shapeways.com/product/2T...li=marketplace
Old 08-01-2019, 06:04 AM   #166
Hex adapters are now available, can anyone confirm what size machined hardware is required, or are they included?
https://www.associatedelectrics.com/.../details/42104
celt is offline   Reply With Quote
Old 08-01-2019, 07:09 AM   #167
Ahh, its factory, might I suggest stock fasteners.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 08-01-2019, 10:10 AM   #168
Not much info on them, I'm guessing no fasteners are included from the one picture they have and that they'll use machine screws either M2.5 or M3 as the stock fasteners are a course thread screw made for plastic.
Old 08-01-2019, 11:39 AM   #169
FB answer was M3 included
Hang up and Drive
Old 08-01-2019, 03:15 PM   #170
Nice new product...
This thing just keeps getting better and better.
Old 08-05-2019, 03:50 AM   #171
Just a free tip. If you are going to upgrade to one of the optional hard plastic parts, as I did. Make sure you first thread a screw thread through the holes before you start mounting .... saves you a lot of stripped screws .... The hard plastic is really hard!
It works great, frame is a lot stiffer.
Cesco is offline   Reply With Quote
Old 08-05-2019, 06:41 AM   #172
Go Buckeyes!
B-MOW71's Avatar
Not sure if it has mentioned here, but my rear axle bearings were sliding out past the screws that hold the bearings in. I put washers on each screw to help hold in the bearing. This may be due to the fact that I replaced the stock screw with SS and the SS may have a smaller diameter head. Just a heads up to watch out for your rear bearings.
B-MOW71 is online now   Reply With Quote
Old 08-06-2019, 05:11 AM   #173
Attachment 382723
Did you use one of the SS kits that are available?
punkindrublik is offline   Reply With Quote
Old 08-06-2019, 06:01 AM   #174
Go Buckeyes!
B-MOW71's Avatar
I did not use a premade SS kit for the Enduro, but I did use Team KNK stainless steel screws. I buy their Monster Bag which has an assortment of different sizes of screws.
Old 08-06-2019, 06:05 AM   #175
I used their Enduro kit, so maybe I should watch out for that. In fact, I already had that screw break out of it's hole. I wonder if that happened after a bearing came loose. Had my whole axle come out on me 30 seconds into my maiden. Didn't get off to a good start.
Old 08-06-2019, 06:22 AM   #176
Go Buckeyes!
B-MOW71's Avatar
It sounds like that might be what happened. Once you add the 3mm washers the bearings will stay seated in the axles and not come out.
I did not compare the SS screws with the stock black screws, so I'm not sure if it is a screw issue or the screw hole placement issue. Either way the washers will keep that from happening again.
I will say, I use Team KNK screws on all of my rigs and I have had zero problems with any of their hardware or products.
Old 08-06-2019, 10:00 AM   #177
Originally Posted by soze View Post
They've got a new Utility bed out for the Sendero.
https://www.associatedelectrics.com/...o_utility_bed/
I like it!
How will this look with my inner fenders and Scalerfab rear bumper? Hate to get rid of them but this looks real good.
Alvinm is offline   Reply With Quote
Old 08-06-2019, 10:38 AM   #178
Won’t be able to use your inner fenders, it has its own
Hang up and Drive
Old 08-06-2019, 02:16 PM   #179
High Clearance SCX10 Rear Crossmember by Harley Designs
I can confirm that this fits and makes the chassis a lot stiffer at the rear. Recon G6 Belgium tested. Take advantage of this for those with a 3D printer.
https://www.thingiverse.com/thing:2286216
(The fuel tank brace is my own design)
Old 08-06-2019, 10:12 PM   #180
Done, thanks for the tip, I feel better about maiden #2 now.
New Associated Enduro Crawler - Free-Mods & Upgrades - Similar Threads
Parts & Upgrades for Element RC Enduro - In Stock! RPP Hobby RPP Hobby 0 06-25-2019 09:37 AM
Coming Soon - New Parts & Upgrades for Element RC Enduro RPP Hobby RPP Hobby 0 05-24-2019 04:19 PM
REDCAT GEN 8 SCOUT 2 | MODS & UPGRADES tips & tricks ANYONE CAN DO! shenlonco Redcat Crawlers 2 01-21-2019 04:52 PM
Upgrades & mods to my JK rtr, good or bad? axial 4x4 crawler Axial SCX-10 5 01-14-2014 01:44 PM
