07-18-2019, 08:51 PM | #41 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| Re: Enduro, here we endurgo!
Well only thing left is the body. Wish me luck, I suck with lexan Sent from my iPhone using Tapatalk |
07-19-2019, 06:17 AM | #42 |
Looking really good! Good luck with the body! |
07-19-2019, 06:40 AM | #43 |
Did you use the metal shock bushings? Im gonna see if an oring will fit on the side Hang up and Drive |
07-19-2019, 06:59 AM | #44 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: Enduro, here we endurgo! |
07-19-2019, 07:04 AM | #45 |
07-19-2019, 07:09 AM | #46 |
07-19-2019, 07:15 AM | #47 | |
| Re: Enduro, here we endurgo! Quote:
SSD Contenders. Cheap hardware, broke off two fricken screws, but ya really like the wheels. Plus maybe I over tightened so may have been my bad Also note they are fairly deep. Had to use like 8mm offsets if I’m remembering correctly at the moment. Otherwise the wheel would rub against the link mount on top of the casters. Sent from my iPhone using Tapatalk | |
07-19-2019, 07:30 AM | #48 |
| Re: Enduro, here we endurgo! Sent from my iPhone using Tapatalk |
07-20-2019, 01:11 PM | #49 |
So as one might expect, ran into issues right away in mocking up the 66’ Bronco body. With it having floor boards it was sitting about an inch high due to resting on top of the receiver box. After much brain storming about maybe getting a smaller receiver box or cutting the existing box to make it shorter, the answer turned out to be staring me in the face the whole time. Thanks to MikemcE suggesting to put the stock battery tray mount in the rear for extra support, it was clear where to move the receiver box to. Simply tapped 4 new holes in the bottom of the box and problem solved! Sent from my iPhone using Tapatalk |
07-20-2019, 06:39 PM | #50 |
I just looked at that RX box also, came up with the same solution, thanks to you! I wish the brace was my thought, but Harley did it first. My need was wiring neatly with motor leads and 1080 switch. Hang up and Drive |
07-20-2019, 06:51 PM | #51 | |
Ha, well yet another idea of Harley’s I’ve used then And yes totally agree. The accidental outcome of moving it, is it’s definitely going to make for some much cleaner wiring. Sent from my iPhone using Tapatalk | |
07-20-2019, 07:04 PM | #52 |
Great body choice, and lovin' people throwing out their unique solutions to fitment situations... Can't wait to see it with paint! |
07-22-2019, 05:09 PM | #53 |
Quarry Creeper Join Date: Oct 2017 Location: The Netherlands
Nice sollution for the receiver box!
07-22-2019, 06:33 PM | #54 |
Quarry Creeper Join Date: May 2019 Location: North Highlands
Glad I read this. I'm just starting on the chassis and I really like that box mount. Kudos |
07-22-2019, 08:48 PM | #55 |
Hey cool! Gotta say after all ideas I’ve “borrowed” from so many sharp people on here, I’m pretty proud to have been able to contribute to a solution. Sent from my iPhone using Tapatalk |
07-22-2019, 11:04 PM | #56 |
Okay calling all tips please. After relocating the receiver box, got my wiring all re-routed. Not a huge fan of the rats nest created by just trying to get the ESC wires down low enough to clear the floor board. So please don’t mention it as I’m really trying not to let it bother me With that completed, I’m ready to brainstorm on body mounting. In trying to get away from body pins I picked up some Extra speed rare earth magnets that come with metal body post to screw the magnet to the top of the post. So no problem there. But being as the under side gets painted I can’t think of a way to glue the other mags to the body with melting the paint away. Would really like to put screws through the body to attach the mags with. In the back this should work cause I can basically hide them using stainless steal screw that blend in with the sticky back diamond plating I’m going to line the entire back area in under the cage. For the front though not sure what I could do to hide the screws. Any tips would be great, or an idea completely different I’m totally open to. Sent from my iPhone using Tapatalk |
07-23-2019, 04:17 AM | #57 |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
I use shoe goo for the underside. It doesnt seem to melt the paint any at all. Alot of people here use shoe goo or e6000 with no problems Sent from my SM-J327VPP using Tapatalk |
07-23-2019, 04:40 AM | #58 |
I use E6000 with no problems. Sent from my SM-G930V using Tapatalk |
07-23-2019, 04:44 AM | #59 |
Rare Earth, Shoe Goo or E6000 Follow the video, be patient and use the clear tape. They hold! Biggest trick is patience!! You really need to wait a week for the paint to cure, then give the shoe goo 24 hours. I’ve yet to lose any paint https://youtu.be/JattsfLcmuw Hang up and Drive Last edited by mikemcE; 07-23-2019 at 06:19 AM. |
07-23-2019, 05:52 AM | #60 |
Pebble Pounder Join Date: Apr 2011 Location: Madison
Just a nonsensical thought.... I don't submerge my rigs, so this might apply to few builders. I cut a piece of lexan and mount the HW1080, switch and receiver in the location of the servo winch area - don't use the wiring box at all. Makes for a very clean, weight balanced setup. Another option.... |
Enduro, here we endurgo! - Similar Threads | ||||
What I'm doing to my ENDURO! | CODYBOY | Element RC 1/10 Enduro Trail Truck Sendero | 98 | 04-10-2020 08:37 PM |
Enduro Funduro | Old n ratty | Element RC 1/10 Enduro Trail Truck Sendero | 3 | 07-07-2019 01:43 PM |
kmc enduro? | flat out | Tires and Wheels | 18 | 11-18-2012 10:59 AM |
The 1/8 Wonder Enduro Race | The Cow | Non Crawler RC's | 5 | 09-22-2010 03:47 PM |
Enduro Cross | twisted | Chit Chat | 7 | 02-05-2008 08:22 PM |
