Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: First kit ever.
Old 07-29-2019, 01:09 AM   #1
Default First kit ever.
I bought my first kit last week after having an SCX10 for a few months and have had a lot of fun building it. Thought I would share its progress and my way of doing things (most of which are probably questionable).
Olliem1 is offline   Reply With Quote
Old 07-29-2019, 01:21 AM   #2
Default Re: First kit ever.
Mass photo drop. I decided to give welding a go and welded up some new sliders for as much weight at the lowest point I could get it. As bumpers are limited right now I chose to pick up an aluminum bumper mount set for an SCX10 and hit them on the bench grinder, the screw hole offset is different so I will be running 2 (instead of 4) bolts for now. Power options are torque master 35t and 1080 with a power eco servo (trying it out, not too sure it is going to be very good). I blew up my front pinion by forgetting to put washers in the 15mm axle extenders so don't do that. Next to come is wiring.
Sent from my SM-N960U using Tapatalk
Old 07-29-2019, 06:14 AM   #3
Go Buckeyes!
B-MOW71's Avatar
Congrats on buying your first kit!
The Enduro is a great kit and I'm sure you will enjoy it!
B-MOW71 is offline   Reply With Quote
Old 07-29-2019, 08:20 AM   #4
digin those sliders!
1FSTLS1 is offline   Reply With Quote
Old 07-29-2019, 12:35 PM   #5
Great choice and build. Do not worry about that servo, i’ve run it on my scx10ii for 8 months now, good value wp servo
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 07-29-2019, 10:23 PM   #6
Still waiting on the new pinion to arrive so have been busy make her pretty. Decided to nylon braid everything to make it cleaner. Progress so far.
Old 07-30-2019, 12:40 AM   #7
Finished the front bumper wiring
Old 10-30-2019, 05:10 AM   #8
Any updates on this build?
Cesco is offline   Reply With Quote
