08-26-2019, 12:00 AM | #1 |
Rock Stacker Join Date: Aug 2019 Location: Moultonborough
| Running in water
I come from a racing/light bashing RC background and have always avoided running them in water, even the ones that are "waterproof." New to the crawling aspect with an Enduro RTR. I know the electronics are pretty much waterproof and the receiver box is sealed pretty good, but what else do I need to be aware of/concerned with when running in water with this guy? I know this is a general newbie question but I wanted to know about my truck specifically as I don't even know if the RTR comes with bearings or bushings for example. Haven't looked that far in the manual yet What extra precautions and after running maintenance should I be aware of with this truck specifically out of the box? Thanks! |
08-26-2019, 08:55 AM | #2 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Running in water Quote:
Why intentionally set your truck up to have problems with rust, mud, dirt, sand in your bearings, electronics and gears. I guess it's ok if you want to tear down your truck after every run. For me, if I wanted to run in water I would get a boat. JMO Ernie | |
08-26-2019, 11:53 AM | #3 |
I'm going to be running my truck in a few local crawler competitions geared toward beginners, and there will most likely be water sections on the course which is why I'm asking. I guess I'll wait for one of the guys on here who are into running up and down streams to answer then. |
08-26-2019, 12:18 PM | #4 |
Newbie Join Date: Dec 2018 Location: Tucson
General advice says after each run flush out the truck with clean water, use compressed air to blow out all the excess water, and if you are running a brushed motor you will need to oil the bearings.
08-27-2019, 12:48 PM | #5 |
Rock Stacker Join Date: May 2019 Location: Boyertown Pa.
I have been know to get in the water, maybe too deep. So far my TRX4 lost one ESC. In defense of the truck, I found one of the screws loose on the ESC. Prior to that I put in a lighting kit and most likely failed to double check the one screw. Lesson learned. Here is what I recommend: 1. Open up the ESC box and put a small plastic bag around the ESC and zip tie it shut. (my RC boat is done this way) 2. Seal the ESC box with a small amount of silicone. Pay special attention to the wire bundle. Don't over due it, one day you will need to reopen it. 3. When you are done running in water, mud and so on, rinse it with clean water. grease, lube and so on. I also use WD40 on my motors. I also bought a spare ESC for my parts box. Better safe than sorry. YMMV good luck! Last edited by Daycrawler; 08-27-2019 at 12:51 PM. |
09-12-2019, 03:30 AM | #6 |
Quarry Creeper Join Date: Oct 2017 Location: The Netherlands
I use conformal coating for my electronics to really waterproof them. It is smart to waterproof your truck, you never know when it will see any water or mud on the trials.
Running in water - Similar Threads | ||||
Running a sensored brushless motor unsensored with water | CoolRunning | Electronics | 9 | 03-22-2017 12:33 PM |
After running it in water and mud? Axles and Trans | gmackhurry | Axial SCX-10 | 3 | 01-11-2015 10:01 AM |
running water in tires with out foam. good or bad? | grass hopper | Newbie General | 27 | 05-23-2012 10:32 PM |
running a new brushed motor in water?? | m1009cucv | Electronics | 2 | 07-06-2011 10:45 AM |
Foam set-up for running mashers on mud and water? | andres-tavares | Tires and Wheels | 4 | 07-28-2007 05:13 PM |
