Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: Little Help
Old 11-05-2019, 01:54 PM   #1
Default Little Help
Hello. I just completed the Enduro kit and it went pretty well. One thing that I am noticing is the front wheels/tires are slightly bowed out on both sides, ie the top of the wheels are pointing slightly inwards. I removed the hubs/wheels and the axles themselves seem to slant in that direction. I cannot find any adjustment point that would allow me to correct.
Anyone else have this issue? Sitting still it is slightly noticeable but driving it is clear.
BTW this is my first crawler build so it may be a silly question...Or just OCD.
ebcdic is offline   Reply With Quote
Old 11-05-2019, 02:13 PM   #2
Gold Star Baby!
Topher Builds's Avatar
Default Re: Little Help
Can you share any pics with the wheels off?
Sounds like you may have your C hubs on the wrong sides of the axle
Topher Builds is offline   Reply With Quote
Old 11-05-2019, 02:54 PM   #3
I will grab some later when I get home. here are 2 I took with wheels on...
Gonna feel dumb if I put something on upside down lol...
https://ibb.co/kqT89YQ
https://ibb.co/SshGn5S
Old 11-05-2019, 03:04 PM   #4
Gold Star Baby!
Those are on the right sides from what I can see but you can try clocking them forward by a spline and see if that helps.
May be worth making sure the rod ends on the tie rod that go behind the axle aren’t over tightened. I didn’t build the kit, but if the manual has a 1:1 image of the link then you can just lay it on top of that to make sure the length is right.
Old 11-05-2019, 03:32 PM   #5
I don't have an Enduro but I'd be surprised if negative camber wasn't built-in
Xx Losungen xX is offline   Reply With Quote
Old 11-05-2019, 06:20 PM   #6
Looks fine, How tall are those tires?
I’m running 4.13” and it’s not as noticeable, normal on this truck.
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 11-06-2019, 08:21 AM   #7
I have a trailwalker that does the same thing. I was concerned about it, but last night at our weekely competition, i looked at 4 other Enduro's and they were all the same.
thirtydaZe is offline   Reply With Quote
Old 11-06-2019, 10:45 AM   #8
Thanks for the information all. I am going to chock it up as a "feature", and will be sure to brag about my "camber" when I take it out...
Old 11-06-2019, 05:12 PM   #9
R2j
SORRCA Committee Member
R2j's Avatar
Mine does the same thing, but to me it looks like the axle housing is bent. It's not a big deal, just looks weird.
Edit:
Must be the plastic parts.....I just installed the SSD metal parts and chamber is neutral now.
Name:  GC Yota7.jpg
R2j is offline   Reply With Quote
