Stock tire bead issue? Has anyone else had issues with the RTR tires not staying beaded? I have them mounted to some SSD wheels and 2 of the 4 keep debeading. Sent from my iPhone using Tapatalk |
Re: Stock tire bead issue? I had no issues mounting them on 2.2 chinaquishs with 1.9 CI dual stage foams. Maybe the stock foams are too wide? https://uploads.tapatalk-cdn.com/201...b89e3e59a4.jpg Gesendet von meinem TA-1004 mit Tapatalk |
Re: Stock tire bead issue? Didn’t think about the foams possibly cause the issue. I have some proline memory foams laying around, I’ll try swapping them out to see if that helps. Thanks. Sent from my iPhone using Tapatalk |
Re: Stock tire bead issue? I've noticed they are a bit hard to mount - My plan is to do what Grimm did, stretch them over 2.2" wheels and use them on my TRX-4 at some point down the road... The TRX-4 bodies are large enough to where 2.2" wheels still appear pretty scale. |
Re: Stock tire bead issue? 3 Attachment(s) I had a similar problem with some cheap Austar beadlocks. I was being lead a merry dance trying to get the bead to lock evenly (or at all) with the rims. So I did a bit of measuring of the original plastic Method rims and realised that the Austar inner rim as a bit small to get the bead in place and pinch it. So I designed a mod...... Basically, I 3d printed a PETG ring with an inner diameter of 54mm and an outer diameter of 57mm - the ring is 24mm in height. This can be fitted over the inner ring of the Austar rim. This gives the bead a proper ledge to press up against and that fixed my issue. |
