Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: Transmission skid plate upgrade
Old 04-08-2020, 06:31 PM   #1
Default Transmission skid plate upgrade
A good amount of the Axial scx10-2 parts fit on the Sendero. Does anyone know if the transmission skid plate cross member will?
jeeptec is offline   Reply With Quote
Old 04-08-2020, 07:12 PM   #2
Default Re: Transmission skid plate upgrade
The inner holes of a SCX skid line up with the holes in the Element chassis, the outer holes do not. You can make it work if you dremel the outer holes to open them up.
svt923 is offline   Reply With Quote
Transmission skid plate upgrade - Similar Threads
Measurements for stock AX10 Transmission mounting plate/skid plate Apoch Axial AX-10 Scorpion 5 04-09-2012 07:53 AM
tcs upgrade skid plate no1970ax1o Axial AX-10 Scorpion 5 02-01-2011 07:55 AM
how do you remove the transmission from skid plate? Bamaswamper Losi Mini-Rock Crawler 3 11-09-2010 06:42 AM
Skid Plate Upgrade Skysthelimit Axial AX-10 Scorpion 14 06-07-2009 11:05 AM
