Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: New 3D Printed Engine Parts from Element
Old 05-28-2020, 04:51 PM   #1
Go Buckeyes!
B-MOW71's Avatar
Default New 3D Printed Engine Parts from Element
This was just announced today! 3D printed engine parts for the Element Enduro.
Free download from Element RC website or can be bought from Shapeways.
https://www.associatedelectrics.com/...aMSa_wTMK2P34A
B-MOW71 is offline   Reply With Quote
Old 05-28-2020, 04:53 PM   #2
Default Re: New 3D Printed Engine Parts from Element
Saw this. Love that they did this!
soze is offline   Reply With Quote
Old 05-28-2020, 04:56 PM   #3
Go Buckeyes!
B-MOW71's Avatar
Yeah, it's cool! I was shocked when I found out!
Already have my 3D printer fired up!
Big thanks to Element RC for offering this!
Old 05-28-2020, 05:06 PM   #4
They are on the ball and I am happy to see this as well.
NCRon is offline   Reply With Quote
Old 05-28-2020, 05:15 PM   #5
Go Buckeyes!
B-MOW71's Avatar
Also, Aaron from Element said that this will work with the IFS, but it will have to be modified.
Element is working on an IFS version to be released at a later date.
Old 05-28-2020, 05:49 PM   #6
Pretty cool!
Looks like they couldn't find the right radiator hose at the parts store, very unsightly. Working up a quick 90 degree adapter would fix this up though.
HumboldtEF is offline   Reply With Quote
Old 05-28-2020, 05:52 PM   #7
What body is the engine installed in?
Old 05-28-2020, 07:49 PM   #8
That's awesome, downloaded!
I wonder how well that block will fit between my wheels wells, guess there is only one way to find out.
Greatscott is offline   Reply With Quote
Old 05-29-2020, 06:26 AM   #9
Go Buckeyes!
B-MOW71's Avatar
Originally Posted by HumboldtEF View Post
Pretty cool!
Ha Ha! Yeah, I agree. I'm going to attempt to draw up one and print one out for mine. Still in the process of learning Fushion 360, but I don't think it should be too hard.
Not sure. This pic is from Element. I think it looks like the RC4WD Blazer body.
It doesn't look to be all that wide. It may fit. I'm thinking about fitting one in my VS4-10 PRO since the servo setup is about the same.
Old 05-29-2020, 08:07 AM   #10
Moderator
JatoTheRipper's Avatar
This is very cool. I still don't own an Element, but I have to admit they are going full force into this segment of RC and they're killing it.
I love the wire insulation radiator hose idea even if the routing isn't realistic.
Old 05-29-2020, 01:49 PM   #11
You should change that then.
I bought the kit version and while not perfect, it's such a well done truck. The fit and finish is classic Team Associated which is always top notch.
Plus, it climbs so well. The only thing I have added is the SSD brass knuckles for some front weight bias down low. This thing crawls so well and that's after going to 75mm shocks and using 1.55 x 4.19 Pitbulls.
TexasSP is offline   Reply With Quote
Old 05-31-2020, 07:07 AM   #12
Go Buckeyes!
B-MOW71's Avatar
The print turned out great!
I’ll post more pics of it in my Enduro build thread after I add some paint and get it installed.
Old 06-01-2020, 08:06 PM   #13
I printed everything out, but I will likely have to make the block and radiator solids again to modify them for my very modified Element. I have no holes for the radiator to mount to, and it interferes with the mounting of the body.
Old 06-02-2020, 06:26 AM   #14
Go Buckeyes!
B-MOW71's Avatar
I went back and took a look at your build. (Great build by the way!) Your servo setup looks similar to mine. My winch servo sits a bit higher than my steering servo like yours.
I made a simple block in Fushion that I glued in to take up the space over top the steering servo.
Old 06-02-2020, 06:50 AM   #15
Yup, was thinking about making a spacer for the steering servo as well, the one you made is nice and clean.
How are you holding everything in place?
Old 06-02-2020, 09:17 AM   #16
Go Buckeyes!
B-MOW71's Avatar
Thanks! I had to keep it simple because I'm still a noob at Fushion 360!
I used a very thin piece of servo tape on top of each servo to hold the engine in place.
New 3D Printed Engine Parts from Element - Similar Threads
What RC parts have you 3D Printed???? vwdaveb Tools, and Procedures 353 02-08-2023 02:49 PM
3D Printed Parts monkeyracing Tamiya XC/CC01 5 05-29-2015 10:20 AM
