Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: STRC Steering Knuckle fitment issue
Old 08-03-2020, 10:43 AM   #1
Default STRC Steering Knuckle fitment issue
As the title basically says, my strc brass steering knuckles will not slide over the IFS control arm mounts. Is the IFS that different from the solid axle? I was under the impression they were the same steering knuckle. Anyone else have fitment issues from strc? Should I try to drill out the knuckle so they slide in or did I just get a bad batch? Neither side fits btw
Sent from my LM-G820 using Tapatalk
nosfanatic2006 is offline   Reply With Quote
Old 08-03-2020, 12:39 PM   #2
Default Re: STRC Steering Knuckle fitment issue
When i built my IFS rig with SSD brass knuckles they didnt fit either, I took a bit of sand paper in a drill and "honed out" the knucles them sevles. I've seen other people put the ball studs in a drill with some sand paper took a bit of material off the stud while it was spinning.
Im pretty sure this is a common thing for whatever reason.
Doomp is offline   Reply With Quote
Old 08-03-2020, 12:44 PM   #3
Thank you. I'll try that when I get home. Bit of a bummer but oh well lol
Old 08-03-2020, 02:37 PM   #4
I had to drill out my SSD knuckles. Its due to the ball stud being larger for the IFS kit.
I think its a metric size in case you have metric drill bits.
At least its an easy fix and we're fortunate enough that this doesnt require an entirely new part.
HumboldtEF is offline   Reply With Quote
Old 08-03-2020, 02:53 PM   #5
Yaaaay stronger parts? Lol
STRC Steering Knuckle fitment issue - Similar Threads
Raw kit Motor fitment issue Lovetoclown Axial SCX10 II 17 11-06-2019 08:45 PM
STRC rear lockouts fitment issue 1967Typhoon Axial SCX-10 13 09-08-2016 08:25 PM
Skid and lower rails fitment issue? 84yoda Axial RR10 Bomber 5 01-13-2016 09:56 PM
Vanquish scale knuckle & steering issue kowalski22 Axial Wraith 39 03-02-2015 09:20 PM
FYI- Golden Horizon beats STRC on fitment it8ezbngrn Axial Wraith 0 06-03-2013 01:00 AM
