09-06-2020, 09:30 AM | #1 |
Rock Crawler Join Date: Mar 2008 Location: Plainfield
| Stealth x ?’s
Has anyone converted the spur to 32p? If running the stock 48p, what’s a good pinion to start with an 1800kv motor? Lou |
09-10-2020, 08:18 AM | #2 |
| Re: Stealth x ?’s
Anyone? Lou |
09-11-2020, 07:58 AM | #3 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: Stealth x ?’s
well gearing seems to be a personal preference. In my limited research on the enduro, I haven't noticed anyone going to 32p. I don't see why you couldn't. I thought I heard the benefit of 48p was less noise. I think the stock enduro comes geared 87t/18t = 4.83x2.6x3.75 = 47.09:1 FDR. I think the lowest that will fit is 14t pinion. 87/14 = 6.2x2.6x3.75 = 60.5:1 FDR. 32p would need to be around 56/13 = 4.66x2.6x3.75 = 45.4:1 FDR I think i have 56/11 on my axial 3 gear which equals 5.09x2.6x3.75 = 49.6:1 FDR |
09-11-2020, 08:23 PM | #4 |
| Re: Stealth x ?’s
Thanks bro. I’ll look into this a little more. Lou |
09-12-2020, 04:24 PM | #5 |
Quarry Creeper Join Date: Jul 2020 Location: Lincoln
| Re: Stealth x ?’s
I converted mine to 32 pitch. Used the Robison Racing Spur. It worked really well so far. Sent from my iPhone using Tapatalk |
09-12-2020, 04:55 PM | #6 |
| Re: Stealth x ?’s
How did you do the conversion? Just swap spurs or was it more involved that that? Lou |
09-12-2020, 04:56 PM | #7 |
| Re: Stealth x ?’s
Just swapped the spur. It was a direct replacement. Sent from my iPhone using Tapatalk |
09-12-2020, 05:07 PM | #8 |
| Re: Stealth x ?’s
Excellent. Lou |
08-10-2021, 10:23 AM | #9 |
Newbie Join Date: Apr 2014 Location: Washington state & Arizona
| Re: Stealth x ?’s |
08-10-2021, 11:51 AM | #10 |
| Re: Stealth x ?’s
It was the 58T spur. I was using a 12 and 14 tooth on 550 sized 3300kv motor. (Couldn’t find much in stock at the time.) I couldn’t find any pinions to fit that motor shaft. I have since swapped motors and went back to the stock spur. Sent from my iPhone using Tapatalk |
08-10-2021, 01:06 PM | #11 |
| Re: Stealth x ?’s
I ended up using the slipper eliminator from the stock, axial plastic 3 gear mold. Actually works like a boss, I'll try to post a pic later. Lou |
08-10-2021, 03:45 PM | #12 |
| Re: Stealth x ?’s
Ok, I typed that way too fast. I would like to use the RR 58T spur with a 22 or 23 T pinion. For use with TRX4 axles, so I need less reduction at the pinion/spur to get in the 40 to 50:1 range. Wasn't sure if that would physically work or if I would be hitting the limits of the motor mount.
09-09-2021, 06:11 AM | #13 |
Newbie Join Date: Jun 2021 Location: Apopka
| Re: Stealth x ?’s
Exocaged on youtube did Ar45 portals with the Stealth X trans. Used a 76t spur and 22t pinion. FYI if you want to try that.
09-09-2021, 09:23 AM | #14 |
| Re: Stealth x ?’s
Bowhouse/SVT just released this Spur gear adapter https://bowhouserc.com/svt-spur-gear...lement-enduro/ |
09-09-2021, 05:35 PM | #15 | |
| Re: Stealth x ?’s Quote:
09-09-2021, 06:29 PM | #16 |
Rock Crawler Join Date: Nov 2019 Location: Erie
| Re: Stealth x ?’s |
09-09-2021, 09:11 PM | #17 |
| Re: Stealth x ?’s
Looks good. This will also work with the TGH 2.low… Lou |
09-10-2021, 09:27 AM | #18 |
Quarry Creeper Join Date: May 2019 Location: Knoxville
| Re: Stealth x ?’s |
09-10-2021, 08:50 PM | #19 |
Newbie Join Date: Nov 2017 Location: Eureka
| Re: Stealth x ?’s
Sweet! I just ordered one. Sent from my iPhone using Tapatalk |
Stealth x ?’s - Similar Threads | ||||
For those of you with a Stealth | Kamikaze | Tamiya TLT Crawlers | 5 | 08-04-2006 02:36 PM |
