02-16-2021, 11:55 AM | #21 |
Pebble Pounder Join Date: Dec 2020 Location: Atlanta
| Re: New guy with new truck.....
Phildirt, as far as steering pull/drift. My RTR pulled to the right or left, I couldn’t adjust it out with steering trim. Always going one way or the other, no sweet spot. In looking closer I found the steering ling was a fraction off, too short and not allowing the left and right spindle alignment to be totally perpendicular. Make sense? You may have already looked at this link and hub alignment. I also hope the steel pivot balls will “tighten” the links, steering and servo up some reducing play and lead to straighter tracking. Hope this helps. Last edited by SloDon; 02-16-2021 at 02:14 PM. |
02-20-2021, 10:42 PM | #22 |
Got to try out my updates today. Like the 12% OD it does pull better. The LCG skid/transmission mount I’m sure also helped. It wasn’t tracking straight so I rechecked all the front link lengths and found one off spec length. Corrected this and with the addition of metal pivot balls it tracks better. I changed all the plastic pivot balls out and the suspension feels tighter and more composed. Climbed some and also did a 1/4 mile up and back trail run. On the longer trail sections I didn’t notice any ill affects from the OD increase. I’m happy! |
02-21-2021, 06:32 AM | #23 | |
RCC Addict Join Date: Aug 2020 Location: Jacksonville
| Re: New guy with new truck..... Quote:
I have SSD Pro44s with Vanquish incision steering links, they are adjusted right. I still think it’s the front wheels turning faster than the rear that causes the wandering. The Enduro axle/linkage steers straight as an arrow on my 10ii and the chassis are virtually identical, only thing different is the transmission at this point. I am going to put my ax10 transmission on my Enduro for grins just to see if it quits doing it. Sent from my iPad using Tapatalk | |
02-21-2021, 12:10 PM | #24 |
Newbie Join Date: Feb 2021 Location: Cave Creek
What model is your truck? I’m a newbie and would love to get back into RC. Thank you. Sent from my iPhone using Tapatalk |
02-21-2021, 05:29 PM | #25 |
Element RC Enduro Trailwalker. https://www.rpphobby.com/product_p/asc40101.htm https://www.rpphobby.com/product_p/asc40101-b.htm Good solid truck. Also good is the Traxxas TRX4 Sport https://www.rpphobby.com/product_p/tra82024-4-blue.htm And the Axial SCX10 II Honcho https://www.rpphobby.com/product_p/ax90059.htm All are good trucks to start with and each has a lot of aftermarket and modification tips out there....... There are more expensive kits/RTR’s out there but these are proven designs which can be upgraded if you choose, but are quite capable right out of the box. Last edited by SloDon; 02-21-2021 at 05:33 PM. |
02-21-2021, 06:06 PM | #26 |
I’d go with the 10ii Cherokee over the Honcho. It’s a little more coin but you get metal links, universal axles, metal trans gears, I believe the other version of the ar44 (not the single piece) and maybe even a better transmitter I can’t remember. There’s a reason most of the 10ii gallery is pics of Cherokees. The Honcho is cooler looking though. Sent from my iPad using Tapatalk |
02-21-2021, 07:00 PM | #27 |
True and probably a better value than the Honcho......if he goes Axial.
02-26-2021, 03:20 PM | #28 |
Ok. My first attempt at body trimming..........don’t look too close! Needed to trim to fit the Vanquish rear bumper. |
03-04-2021, 12:03 PM | #29 |
On deck for the next work session......
03-05-2021, 05:41 AM | #30 |
Share the results on that motor swap. I have a 23t sport I was going to swap in but I think it is the trail master. Thought 12t would be a little fast but I know that varies by motor...What pinion gear are you using? Sent from my iPad using Tapatalk |
03-05-2021, 12:48 PM | #31 |
Staying with stock gearing per Holmes Hobby recommendation for now. Will see how it performs. |
03-06-2021, 06:40 PM | #32 |
Well ....... I didn’t install any of the new parts. I ran the heck out of it instead. Met two other crawlers at the lake. Had a blast. She has a lot more scapes and scratches, but she held her own against a VS 410 and new 10.3 Gladiator. With the 4.19’s there were a few obstacles she couldn’t overcome. But all in all the balance is great and with 3S power she pulls! |
03-07-2021, 09:41 PM | #33 |
Sunday evening rig cleaning time.....found some new scrapes and some rear bed damage. While cleaning changed out to harder shock mounts. I know this isn’t Comp quality stuff, but it’s just my simple trail/crawling truck. I’m thinking some mesh drywall tape and shoogoo to reinforce the rear bar mounting points. Any other ideas? |
03-13-2021, 06:12 PM | #34 |
Decided to just leave the roll bar off.....took it out to play after work Friday.
03-19-2021, 09:48 PM | #35 |
Ok....finally got a chance to drop in the Holmes 550 12T, the MKS servo and the SC480X ESC. Only ran in around the house but I really like the changes. Faster steering, smoother motor and more control. |
03-28-2021, 11:02 PM | #36 |
Really like these latest changes. I think that’s it for know with the Trailwalker. I have it where I want it. It’s a nice class one rig. I’ve got a new kit to build a class two truck. Some pics on the run after the last upgrades.... |
05-07-2021, 11:38 PM | #37 |
I need to show the Enduro some love. Hope to crawl some this weekend.
05-16-2021, 11:14 PM | #38 |
Got to crawl the TrailWalker Saturday! A fun charity comp and crawl for a local animal shelter. After running my other truck in a comp that day I was surprised at how quiet the Element drive train still is after hours of run time. I hadn’t run it back to back with other trucks in a while and had forgotten how quiet and smooth the truck runs. Still a great trail truck! Sent from my iPhone using Tapatalk |
05-17-2021, 07:28 AM | #39 |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
I agree with you. I ended up selling both of my TW’s and kind of miss them... incredibly capable out of the box.
07-07-2021, 11:03 PM | #40 |
I got a deal on a winch over th3 holiday weekend. Reefs RC 299 LP. Installed it on the TrailWalker………. I also bought inner fenders and a Bomber interior. I plan on going thru the truck and making some updates. |
New guy with new truck..... - Similar Threads | ||||
New Crawler Guy,New Truck | kkipp9 | Axial SCX10 II | 4 | 08-14-2016 04:47 PM |
another guy asking for short truck advise | jamesthe1v | Non Crawler RC's | 6 | 03-01-2016 05:44 PM |
Hummer trail truck from the new guy | 89crxsir | 1.9 Scale Rigs | 0 | 02-22-2009 12:01 PM |
new guy new truck | eitmhl | Tamiya TLT Crawlers | 3 | 11-08-2005 06:50 PM |
