10-23-2023, 01:24 PM | #1 |
Quarry Creeper Join Date: Mar 2020 Location: Las Vegas
| Bushido Questions
So I'm asking myself why this interest in the Bushido.? I see that Axial dropped their Bronco, and I'm wondering if the deck is stacked against getting these things to crawl like their longer wheelbase companions. I'm kicking around a build idea for the Bushido, but is the uniqueness of the truck mostly due to the body and looks, or does it crawl with a significantly different feel than the longer wheel base trucks.? I realize it won't be a comp truck, but does it feel seriously handicapped on steep, technical terrain? s. |
10-23-2023, 01:55 PM | #2 | |
RCC Addict Join Date: Jan 2019 Location: Corvallis, OR
| Re: Bushido Questions Quote:
Aren’t both the 10.3 bronco and bushido 12.3” wheel base? That’s one of the reasons I lost interest in the bushido as soon as i found out they just made the body huge to fit the standard 12.3” chassis. Maybe that is swb to you, idk. Every rig I have at the moment is 12.3 besides my 10.3 gladiator. Regardless, care to share the build idea you have? Sent from my iPhone using Tapatalk | |
10-23-2023, 02:18 PM | #3 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
Wheelbase on Bushido is 11.8 Shorter, but should be shorter yet. I understand the body is large, like the 10.3 early Bronco Vaterra designed a beautiful early bronco body, the WB was truly short at 10.95 Last edited by smog; 10-23-2023 at 02:20 PM. |
10-23-2023, 02:23 PM | #4 |
Greetings T, My thoughts were to build it into portal with their new X transmission, and see if it would be a fun rock/boulder crawler. Your comments on the body are spot on and I hadn't been able to put my finger on it what I didn't like about the truck, but that does strike as an odd fit. Looking over the specs, and I read that it's a 11.8" wheelbase, but I haven't put one in my hands. Here are the specs: Body Features
Lemme know your thoughts if we assume it's 11.8".? Maybe a different body? s |
10-23-2023, 03:35 PM | #5 |
| Re: Bushido Questions My UMG clocks in at an 11.4 WB and it's noticeably more agile. Imagine there'd be a similar feel to an 11.8 if your used to standard WB trucks. Has no problems on incline - in fact, it's one of my best overall performers.
10-23-2023, 03:42 PM | #6 |
Interesting intel. Many thanks, s. |
10-23-2023, 03:48 PM | #7 | |||
I regret not getting a umg10 so bad. Quote:
Yep, that was my mistake. All I remember for sure is that once I saw it side by side to a Phoenix for reference I lost interest. Quote:
Doing the math on the wheelbase it scales out to around 1/6.77 That sounds like a very interesting idea and I’d like to see it. They certainly did a good job on the body styling wise. I understand the limitations manufacturers have with scaling bodies to fit existing setups, or just wanting certain specs to fit into what’s most common. Sent from my iPhone using Tapatalk | |||
10-23-2023, 04:27 PM | #8 |
Yeah, I was thinking with portals and slightly smaller tires just to see how it would look. I might just get parts rather than the RTR, knowing I'm gonna replace most bits. I'll kick it around a bit, but I appreciate everyone's input and thoughts. Much appreciated. s. |
Bushido Questions - Similar Threads | ||||
JDM74's Bushido | JDM74 | Element RC 1/10 Enduro Trail Truck Sendero | 27 | 11-29-2023 02:44 PM |
HELP! Axle questions/ Diff questions | DirtyChevy45 | Axial Wraith | 17 | 08-06-2020 09:17 AM |
lipo questions with charger questions can you all help | champ198 | Electronics | 16 | 05-02-2013 01:24 PM |
lipo questions with charger questions can you all help | champ198 | Electronics | 0 | 04-30-2013 05:54 PM |
Questions questions questions quest qowirnl | RYY | Newbie General | 11 | 10-04-2006 08:18 PM |
