Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Element RC 1/10 Enduro Trail Truck Sendero
Thread: Gatekeeper High Clearance Links
Old 06-05-2023, 11:43 AM   #1
Default Gatekeeper High Clearance Links
I want to install high clearance lower front links on my Gatekeeper. Do I also need to install high clearance upper links? I don’t know if the new high clearance lowers will interfere with straight upper links. Thanks.
crn337 is offline   Reply With Quote
Old 06-05-2023, 11:50 AM   #2
Default Re: Gatekeeper High Clearance Links
Nope, you can do just the lowers
IronArcher is offline   Reply With Quote
Old 06-05-2023, 11:50 AM   #3
Old 06-05-2023, 11:51 AM   #4
Old 06-05-2023, 11:53 AM   #5
Old 06-05-2023, 12:01 PM   #6
Thanks. Would I just get the same length (100mm) or do I need to add length to compensate for the bend.
Old 06-07-2023, 04:40 PM   #7
Not sure, I just bought the kit that had both, and just put on the bottoms
Theoretically, you would just measure the length between the balls, not looking at the bend.
Old 06-09-2023, 02:54 AM   #8
rob5059's Avatar
You just need the Element 100mm bent links.
rob5059 is offline   Reply With Quote
Old 06-09-2023, 09:14 AM   #9
Or for something a bit heavier duty, try these.
https://club5racing.com/husky-link-h...r-enduro-ecto/
Though, they show them as 107mm links…
Old 06-15-2023, 09:49 AM   #10
Regarding the high clearance link kits like the one from Club 5 Racing, what’s the point in changing the front upper or the rear links? I understand swapping out the front lowers, but none of the other links are exposed to possible damage. Am I missing something?
Old 06-15-2023, 01:54 PM   #11
Not sure.
The bad side of me thinks it’s just a way to sell more links, the good side of me says maybe there is something I missed here.
I just didn’t feel like adding the heavier links on top.
Old 06-16-2023, 02:49 AM   #12
rob5059's Avatar
If you run a Artful Dodgers skid, the bent lowers will touch the straight upppers. It will give you the clearance so they do not rub.
I personally prefer straight links on the front.
Gatekeeper High Clearance Links - Similar Threads
D-Links High Clearance links and Derlin uppers Timmahh Redcat Crawlers 0 03-07-2022 06:04 PM
High clearance links JMHZ2401 Element RC 1/10 Enduro Trail Truck Sendero 0 01-13-2021 05:24 PM
high clearance links Highboost73 Axial SCX-10 1 06-13-2010 08:08 AM
high clearance links Mac10 General Crawlers 16 08-21-2007 10:05 AM
