07-12-2009, 10:12 PM | #1 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
| berg steering
OK, so i am building a burg... there i said it...... i got it to a roller in about 3- 4 hours where i think it will be a good start... but no steering yet.. sooo.. what steering is everyone running and why????:? i have not seen one yet that thrill's me...:? thanx pic's might post later... |
07-12-2009, 10:17 PM | #2 |
Heres my homemade WBTA setup. |
07-12-2009, 10:25 PM | #3 |
hey 666 how is that on the servo... looks like it would put unwanted strain on the servo... it is out of the way... |
07-12-2009, 10:49 PM | #4 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Didn't want to use the stock mount because the of the clamps hanging below the axle tube. |
07-12-2009, 10:56 PM | #5 |
I was thinking of using one stock clamp all the way over by the gear box and the threaded hole by the shock mount with a carbon fiber plate to mount the servo on... still not sure yet.... thanx keep the pictures comming........ |
07-12-2009, 11:28 PM | #6 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I've been happy with my ckrc tie rod so far. It's not pretty after I took the dremel to it but it works. I like Yotachumps setup the best myself but I haven't driven it yet. Switching from my current toe-out to his toe-in setup will probably be a little weird to get used too when I get one though. |
07-12-2009, 11:36 PM | #7 | |
If you would like the 1:1 template to make your own then PM me with your email address. | |
07-12-2009, 11:51 PM | #8 |
Now thats very clean and simple just not sure why the servo has to sit off center on one side??? thanx anyway the servo horn can point down????? only by raising it up maybe??? Last edited by roksloski; 07-12-2009 at 11:54 PM. |
07-13-2009, 09:57 AM | #9 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
Here is my steering set-up that gathered some attention at our last GTG. It os a modified CKRC setup with an adjustable extension to set toe, and a delrin guide plate to guide the tierod movement 100% of the throw. Works extremely well. |
07-13-2009, 10:33 AM | #10 |
i have seen those work, and they work pretty well.. the ones i have seen were a little floppy because they didnt have delrin plate like you do.. good idea why the axial bent rod ends..??? i never had good luck with any axial rod end, the plastic is so soft i have stretched them out, then the ball is loose..... |
07-13-2009, 10:40 AM | #11 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
Crawler Design Works OTA/BTA........Love It !!!! |
07-13-2009, 11:48 AM | #12 | |
07-13-2009, 11:49 AM | #13 |
07-13-2009, 03:19 PM | #14 |
Rock Crawler Join Date: Apr 2009 Location: Sonoma County
| steering
Hey Mike i will have a ckrc steering available when my yotachump steering shows up! It has al the necessary mods to fit, just like big_117's
07-13-2009, 03:33 PM | #15 |
Rock Crawler Join Date: Jun 2008 Location: dublin
mike.. save yourself a lot of time...CDW STEERING KIT |
07-13-2009, 06:08 PM | #16 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
07-13-2009, 08:53 PM | #17 |
07-17-2009, 11:02 PM | #18 |
Newbie Join Date: May 2008 Location: Sebastopol
| Order |
07-17-2009, 11:25 PM | #19 |
