Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: TAG Team - binaryterrors 09 Rig
Old 03-07-2009, 03:18 PM   #1
binaryterror's Avatar
Default TAG Team - binaryterrors 09 Rig
Well thanks to The Eye allowing me to be on the TAG Team and getting to use some great products for the 2009 season. Well let the build thread begin.
Axles: Berg, front clocked 22.5 degrees
Body: J-Concepts "Stage Killah", Painted by The Butler
Chassis: The TAG - custom tattooed
Shocks: Traxxas Big Bore XL's
Upper Links: Revo 112's fron and rear, rear has 1 4mm pacer and long offset Kyosho rod ends
Lower Links: TAG Line Medium Clearance custom engraved
Steering Link: Kamikaze Kustoms
ESC: Tekin FX-R
Steering Servo: JR 8711
BEC: Castle Creations @ 6.2v
Dig Switches: 22amp Honeywell with 100gram force
Dig Servo: JR 185S (ultra micro)
Battery: Flightpower 3S 1345
Wheels: DNA Snipers - customized with countersunk rins and screws for less hang ups.
Tires: HB White Rovers and Panther Cougars
Ground Clearance: 3.25" to 3.38" drooped out
The fun begins in the barebones set up
Looking forward to the Omaha comp. The rig is very predicatble and smooth. Also the small skid plate makes for very good clearance in and out of the deep holes.
binaryterror is offline   Reply With Quote
Old 03-07-2009, 03:32 PM   #2
Clean rig. The custom engraving is sweet, gives it a personal touch, so many rigs now look a like. Where you gonna run your battery?
TEDROCKZ is offline   Reply With Quote
Old 03-07-2009, 05:12 PM   #3
I run the battery on the back axle. Right now on the KK electronics plate.
Old 03-08-2009, 06:57 AM   #4
It's about time, I thought you were ashamed of it Now ya gotta figure out how to drive it
Later
Farmer
Farmer is offline   Reply With Quote
Old 03-08-2009, 09:53 PM   #5
ghetto fabulous newbie
What foams you using in you HB tires? they look nice and full
yotachump is offline   Reply With Quote
Old 03-08-2009, 10:07 PM   #6
09 RCA champ!
VERY cool build im really liking the paint job, too..
rednck21 is offline   Reply With Quote
Old 03-08-2009, 10:32 PM   #7
WWW.THEROXBOX.COM
Looks great ....
The Eye is offline   Reply With Quote
Old 03-09-2009, 06:56 AM   #8
Panther Soft's (non mem). Cut to 1.875" wide.
Old 03-09-2009, 11:29 AM   #9
what length axial post did you use for the servo rod?
ol' gravy leg is offline   Reply With Quote
Old 03-09-2009, 07:22 PM   #10
40mm
Old 03-09-2009, 07:40 PM   #11
Looks great Binaryterror!
Btw, in the first pic it looks like your castor needs adjusted (shorter uppers). Maybe its just the picture angle.?
Anyway, very nice build
Trugg is offline   Reply With Quote
Old 03-09-2009, 07:54 PM   #12
I ended up adding 4mm spacers to the lower section of the front. Got me a touch closer to 12.5 (Stock is 12 3/8") and fixed the caster. The first pic were a quick build, hadn't set anything in stone. Might also go 1 hole lower on the front links.
Old 03-09-2009, 08:23 PM   #13
Cool, how do you like the f400 foams? I ordered a set the other day. How do they compare to the NWTT all-weather reach foams (or similar)?
Old 03-10-2009, 06:26 AM   #14
They seem like the best foam out. I always find my tires being best with them, be they Panthers, Chisels, or now the Rovers.
For the Chisels and the Panthers I run 2" wide...I had these 1.875" ones made on accident for something else, but they work in the Rovers well. Stiff enough to provide sidehill support but soft enough to make the tires still work.
The NWTT were good for about 1 day, but then they'd get soft and mushy. I got tired of working with them all the time to make sure they were "fresh" for the next comp. My rig isn't heavy, but these foams are pretty soft compared to most others.
Old 03-10-2009, 03:36 PM   #15
Do you like the panthers or the hbs better?
How much does the rig weight?
CrawfishStu is offline   Reply With Quote
Old 03-11-2009, 06:21 AM   #16
Its a toss up. The Panthers perform better all around, but lack the clearance of the Rovers. I think a taller Panther would rule the 2.2 world.
I'll have to get that for you...never weighed the whole truck.
Old 03-11-2009, 08:13 AM   #17
Thanks for the info. Seems like lot of folks are happy with the rovers. Nicely built rig.
Old 07-24-2009, 11:39 AM   #18
Big update since I was given an Invite for 2.2's in MiRCa by finishing 2nd in point for the first 4 comps.
I've been working with The Eye on some new goodies...Time to build a bodiless idea and we did.
Discard the look of the green panels, they were just there for a quick and dirty mount...turned out very John Deere green.
Old 07-24-2009, 11:41 AM   #19
dezfan's Avatar
Green, what are you a tree hugger too?
Good luck at Nat...Worl...Whatever it is this year.
dezfan is offline   Reply With Quote
Old 07-24-2009, 11:49 AM   #20
im liking that bodiless setup more than other ive seen....minus the color of course lol.
slowngreen is offline   Reply With Quote
