07-24-2009, 03:15 PM | #1 |
Pebble Pounder Join Date: May 2005 Location: san francisco
| born-again widow
mfm widow bergs w/ axial outers and tlt kingpins clocked creepy crawler shocks running 60/40 droop jp lockouts mamba max/cc/cs180 manley dig switches blue rovers on eritix comp heavies custom links and steering- new links for next season |
07-24-2009, 03:24 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
looking good....if i were to change something i would get a Punkrc dig switch and maybe a different steering setup just to save the horn from so much abuse but that about it.
07-24-2009, 03:47 PM | #3 |
I used to have a pretty neat over the axle steering setup, but it flexed a little to much. This is a stronger steering setup for sure from what little testing I have done today. Since I clocked my front axle alittle farther than normal I can't run a conventional setup like Kamakazi, yotachump..etc. The front of the servo would sit further out than the tie rod now, thats why I laid it at an angle. That punkdig sure is smaller and lighter, but I'll save that for the next comp build, since this one is reliable.
07-24-2009, 04:04 PM | #4 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
Looks good Scott! Nice job on the servo mount. |
07-24-2009, 04:36 PM | #5 |
right on going to g-tec at 4 to test it out.
07-24-2009, 11:01 PM | #6 |
RCC Addict Join Date: Mar 2008 Location: SSF
Damn son! you've been working. Looks great!
07-25-2009, 11:03 AM | #7 |
it only took two hours of limping up and down to the garage to make everything. works ok, the steering did have more force and didn't flex other than the plastic servo mounts to the plate. Yea, it did get hung up on rocks, but can't really say if its any worse than with the ota steering I had before. One issue is either cog or shocks unloading. I'll keep tinkering, but I am sure I will be making a new comp car for next season.....mabey some bullies so I can compare them. |
