09-28-2009, 07:14 PM | #1 |
Rock Stacker Join Date: Mar 2008 Location: in my cave
| Tearing tires
Does anyone have the problem of the Vanquish High Steer Knuckle Tearing (or Chewing Up) the inside of the tire. I Have The Hpi Plastic Wheel with Rovers.
09-28-2009, 08:08 PM | #2 |
have you chopped off the end of the arm? if you're using the inner hole, chop the arm off at the outer hole so it doesn't stick out past your tie rod at all.
09-28-2009, 08:12 PM | #3 |
Turn them around like this.... |
09-28-2009, 08:13 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: Behind the wheel
Ive got the same problem with my ax10. panthers, f400, integy knuckles. Rips em up at will. |
09-29-2009, 03:30 PM | #5 |
Pebble Pounder Join Date: Jan 2009 Location: here
shorter arms or bta i did both at the same time.
09-29-2009, 10:43 PM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
is it your home made steering.... |
09-29-2009, 10:45 PM | #7 |
Hateraide Join Date: Dec 2008 Location: Mission BC
make sure there is no exposed bolt, sand the corners and edges make sure there not sharp
