12-09-2009, 01:51 AM | #1 |
Newbie Join Date: Sep 2007 Location: Bentonville
| Berg Tracer 2.2
I know a few folks are trying this rig out. I have ran into a problem on the front end. The outer cvd is attached to the axel via 2 set screws tightened down on 2 flat spots on main axle. Well my problem is that I cant seem to be able to keep the set screws seated on the flat spots. I have rounded off the end twice. I have tried to file them down and also to groove them but nothing has worked yet. Any suggestions?
12-09-2009, 07:06 AM | #2 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Does anybody know if the super 300 CVDs will work on the new axles.
12-09-2009, 07:33 AM | #3 |
Quarry Creeper Join Date: Jul 2008 Location: Newark
12-09-2009, 05:19 PM | #4 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
Super 300s are currently being designed/made by sds customs. If you were really desperate you may be able to fit a berg final gear with the lockers and then modify existing super 300s similar to what they did with HR axles. Kieren |
12-09-2009, 11:23 PM | #5 |
| Here is some pics
Here are a few pics showing the problem area. Sorry for quality they are from my phone I know where to get the replacement parts, But want to find the issue before putting a new shaft in. |
12-10-2009, 08:26 AM | #6 |
Rock Stacker Join Date: Jan 2009 Location: Aurora
I had mine loosen up once. I put some loctite on and has been OK since, but I still check them often along with all my other screws So put a new shaft in and loctite and go have fun |
12-10-2009, 09:40 AM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Locktite and check them after every run. Mine are holding up fine so far. Very interested to see if/how the 300s will do away with the the through axle?
12-10-2009, 11:10 AM | #8 |
| faulty shaft
I think I just got a bunk drive shaft. Cause I used loctite on all screws and the screws didnt come loose it is what chewed the shaft up. Guess we will see. I ordered 2 more shafts and alot of other spare parts. |
12-10-2009, 03:06 PM | #9 |
Yeah you must have got a incorrectly hardened one or something:? Because I have had my cvds come loose in the middle of a comp and had me driving on them pretty hard in my books, and the shafts still look great. The super 300s will have to split in the middle, so I would assume that means that, either sds customs will have to make a locker some how or will we have to swap in a v1 berg final gear and locker. Kieren |
12-10-2009, 08:18 PM | #10 |
Pebble Pounder Join Date: Oct 2008 Location: jackson, CA
Things to do prior to loctiting the grub screw.
Things NOT to do.
