10-09-2010, 11:19 AM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: Bad Axe
| Berg steering thread?
Needing to redo the steering on my Berg, just wondering what everyone has done with theirs? Please post pics showing servo mounting, tie rod and knuckle setup. Thanks! |
10-09-2010, 12:34 PM | #2 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
| like searching threads or tips sticky's isn't good enough. |
10-09-2010, 01:15 PM | #3 |
| I was hoping to get alot of diffrent Ideas all in one thread instead of spending hours looking through single build threads. Search "steering" in the berg section and you get 185 steering related threads, some are about steering, some only mention steering. If I spend 5 minutes in each thread I would be looking at over 15 hours of brousing. You may have that kind of time, but I don't. I did search this topic, several times, found out that this is a very broad topic, that's why I was hoping to get it all combined in one thread, if we get enough info in one thread then it could be easily linked or searched or even made a sticky. I am sorry for asking the question, maybe later tonight I will have a couple hours to search some more..... right now I'm going to the garage to work on my rig |
10-09-2010, 02:48 PM | #4 |
I wanna be Dave Join Date: Oct 2008 Location: I miss Rowdy
There is not really and BEST STEERING threads out there, but some searching on "BERG STEERING" should yield some good results. I just checked and about every good thread is listed in the first 2 pages. the 86jeep BTA setup is the most popular right now, it basically sandwiches the servo between the motor and the axle tube so the servo sits very low in the truck. A bit of grinding is needed on the axle tube and where the motor mounts to get everything to sit right but its not too bad, Another one is the RCInnovations steering kit, Its very easy to set up and works very well. CDW makes a nice kit, CKRC makes a nice kit, Just look at people's build threads and see what they are doing, A little research can go a long way to help you decide. |
10-09-2010, 04:06 PM | #5 |
Rock Crawler Join Date: Dec 2007 Location: T1E Country
Clover Custom Design does a version of the 86jeep steering mod. Contact 66bronco (Bryan) if you are interested. RCInnovations steering kit worked well for me when I ran it. |
10-10-2010, 12:46 AM | #6 |
RCC Addict Join Date: Nov 2007 Location: somewhere
if u dont have the cash for someone else to do the work on the 86jeep steering or the abilty to do it urself... RCInnovations steering kit works the best out of the bunch that i have tried
10-10-2010, 10:12 AM | #7 |
I wanna be Dave Join Date: Jul 2006 Location: Elberfeld
10-10-2010, 10:35 AM | #8 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
| He was just asking for pics,give him a brake and post pics. |
10-10-2010, 10:36 AM | #9 |
10-10-2010, 10:36 AM | #10 |
10-10-2010, 10:38 AM | #11 |
Rock Stacker Join Date: Apr 2009 Location: st.george
Does any body know if you can use mayham wicked js wheel with the ota steering because of the clearance on the inside of the beed lock. Please let me know. |
10-10-2010, 10:58 AM | #12 |
Mayhems have no clearance issues with any steering setup.
10-10-2010, 11:04 AM | #13 |
10-10-2010, 11:06 AM | #14 |
RcI with VP Berg knuckles: |
10-10-2010, 11:11 AM | #15 |
I tryed to put my mayhams on ckrc steering with no luck it rubs really bad on the bead lock rings did not know if vp would have the same prob ?
10-10-2010, 11:17 AM | #16 |
10-12-2010, 06:10 AM | #17 |
Didn't know CKRC knuckles didn't clear. A buddy runs them with his mayhems and doesn't have any clearance issues. He must hav modded them to work then.
10-12-2010, 03:11 PM | #18 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
You can clearance the knuckles or countersink the beadlock screws with mayhems and ckrc knuckles.
10-12-2010, 09:31 PM | #19 |
Its not worth it.
10-12-2010, 09:37 PM | #20 |
| Why isn't it worth it?? Its a simple modification that allows you to use the parts as they were intended. The VP knuckles are a bolt on application, where the CKRC's need a little modifying. CKRC knuckles are now the only knuckle design that I know of that has clearance issues on Mayhems. I wonder if they have clearance issues on any other wheels? |
