Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > EnRoute Berg
Thread: Berg knuckles vs AX10 knuckles
Old 10-20-2010, 01:25 AM   #1
sim
Default Berg knuckles vs AX10 knuckles
I see that SDS Customz Super 300 CVDs for the Berg comes in two forms, one for Berg knuckles and one for Axial (AX10) knuckles. When and why do people use Axial knuckles? For zero ackermann?
What's the physical differences between the two CVD's? I'm planning a custom build out of possibly Berg or HR axles or both, so this info would help me greatly.
Thanks.
Btw, I searched.
sim is offline   Reply With Quote
Old 10-20-2010, 02:28 AM   #2
Tossin' Salad
The Axial version was made to fit the Axial AX10 axles. That is why these are offered to fit both sets of knuckles.
If you are going to run Berg axles, just get the Berg knuckle style of CVDs.
KC_JoNeS is offline   Reply With Quote
Old 10-20-2010, 04:56 AM   #3
Thanks.
Btw, I searched.
Before VP made high steer berg k's, only the axial fit version was available. I believe the difference is the OD's on the stub shaft, If someone could chime in to confirm.
ram_tough is offline   Reply With Quote
Old 10-20-2010, 09:27 AM   #4
Ex Nor-CalRCRC slave
gunnar's Avatar
The Stock Berg and Axial knuckles are diferent, the arms that hold the knuckle onto the C (where the bushings fit in) are longer, which puts the inner bearing farther away from the C. Not sure of the exact difference in measurement, but it's roughly around .02"
gunnar is offline   Reply With Quote
Old 10-20-2010, 09:34 AM   #5
Nope....there are three versions....one for the Axial axles......and two for the berg axles (one for stock berg knuckles, one for axial knuckles).
JeremyH is offline   Reply With Quote
Old 10-20-2010, 04:51 PM   #6
sim
Thanks,
Just to make sure I'm getting this right, it's the Berg that has the longer arms and not the AX10?
Edit: realised I described something totally wrong earlier. Nevermind that.
Old 10-20-2010, 04:55 PM   #7
Tossin' Salad
Ah yes...of course...for those that want to use the Axial knuckles with Berg axles.
Learn something new every day.
Casey
Old 10-22-2010, 04:01 AM   #8
sim
So, if I'm building a new Berg, and I want zero ackermann, I would choose
- Super 300s for Berg with axial knuckles
- VP zero ackermann AX10 knuckles or similar
- Axial offset wheels
If I want to run Berg offset wheels for narrower width, less scrub radius, I'd get...
- VP high steer Berg knuckles or similar
- Berg offset wheels
Does this sound about right?
Old 10-22-2010, 01:17 PM   #9
The difference between the berg k's and ax k's is from the king pin to the inner stub axle bearing and is very minamal. You won't see any difference in track width. In fact I'm running vp berg k's on my ax-10 now with no problems and maybe a touch better steering radious. Hope that helps
greencrawler is offline   Reply With Quote
Old 10-22-2010, 03:51 PM   #10
kineteks's Avatar
It's exactly a 1mm difference. VP Axial knuckles on Berg axles will give you a 2 mm narrower track width, but you'd need the Super 300s for Berg/Axial combo or sub 3mm wide inner knuckle bearings for the 4mm wide standard parts.
kineteks is offline   Reply With Quote
Old 10-23-2010, 02:35 AM   #11
sim
Thanks everyone for clearing everything up for me
Old 10-23-2010, 05:23 AM   #12
i got burg k on my axial scaler and it works
richardgarrett56 is offline   Reply With Quote
