slw hub??? I've tried searching but could not find what I need, so if it has been posted already I'm sorry. So I've went with slw's 1'' on the front of my berg. Now the 8mm socket I have been using don't fit in the hub, is there a thin wall nutdriver or socket out there I can get? Thanks! |
I actually just grinded mine down but I think the Dynamite hex driver works. |
I used a dremel and just ground the outside of the wrench it has a little taper to it it works just fine even being really thin at the end |
Go to ace or whatever buy a cheaper nut driver and grind it down that will fit for sure I think I picked one up for like 3.99 |
I believe that the O'Donnell tools have a thin enough wall to get in there."thumbsup" |
I use a Craftsmen 4-1 screwdriver. Just remove the tip from shaft and it fits very well. I know ALOT of guys just grind down what they need though. |
Thank's guy's for all the very helpful info."thumbsup" |
I just bored out the hub just enough to use whatever wrench I wanted. ;-) Be careful... |
O'Donell X2! |
The craftsman 7mm nut driver, part# 41983, fits without grinding anything either. |
