11-08-2010, 02:08 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: Land of the Cactus
| BJ V4 rear shock mount problem
i have almost finished my build of a ytc bj v4 using berg axles but whats stopping me is when i mount the top of my 4" losi shock to the inner part of the chassis at the stock locations, my spring or threaded nut will hit the outer chassis during articution and greatly limit its movement, only half of what im getting up front or less. I've tried multiple spacer sizes and tried flipping the shock. nothing is working. Pease someone guide this green horn down the right path!!!!!
11-08-2010, 06:26 AM | #2 |
Can you post a picture of youre setup?
11-08-2010, 07:17 AM | #3 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
You need to limit the shocks.
11-08-2010, 08:07 AM | #4 |
RCC Addict Join Date: Dec 2007 Location: Ward, SC
Limit them externally .5"
11-08-2010, 08:17 AM | #5 |
It is supposed to do that it acts as a shock limiter since most new builders do not know how to or want to limit the shocks.
11-08-2010, 08:53 AM | #6 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
thank you guys.... they are all correct, the shocks do need to be limited. |
11-08-2010, 09:12 AM | #7 |
Quarry Creeper Join Date: May 2008 Location: Ruhr Valley
or 3.5 inch big bore with tra5347 Rodends (shockcapmod) ??
11-08-2010, 09:45 AM | #8 |
| thanks for the info
thanks guys for all the info. i can't seem to get my cam to work for some reason, i would love to post some pics of my setup. i do realize the shocks need limited, but right now the rear axle may move up a quarter of an inch from flat before it hits the outer part of the chassis. to me thats just way to limited. has anyone ever tried to put 80mm shocks on instead and attach them to the chassis in the very back where the last chassis brace is connected? i tried this already with the 4" losi shocks and i get loads of articulation but the stance is way to tall.
11-08-2010, 09:51 AM | #9 |
Another thing to consider is the amount of clocking that you have? If you rock the tubes back a lot, then that will change the geometry of the rear shocks quite a bit.
11-08-2010, 11:00 AM | #10 |
Rock Crawler Join Date: May 2007 Location: Prescott
Lower link length will make a difference. I have been playing with this for a week now and I finally have it working the way I like it too. I will update this post with link lengths that I am using when I get home. Keep in mind what works for one person may not be the way you like yours setup. |
11-08-2010, 12:29 PM | #11 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Are you spacing the shocks out at the chassis at all? I have to come out to get a better clearance and clean working shock without the binding.
11-08-2010, 12:42 PM | #12 | ||
11-08-2010, 12:54 PM | #13 |
| On the rear of my truck, I space them out with a Traxxas rod end inside the shock end and a JND cone spacer. Works perfectly. I am running Kyosho shocks.
11-08-2010, 03:51 PM | #14 | |
Quarry Creeper Join Date: Jun 2008 Location: Portsmouth UK
This sounds the most probable cause. If the shocks are rolled back with the axle then you`ve already lost some of the movement. | |
11-10-2010, 09:47 PM | #15 |
| Shock problem solved
FINALLY FIGURED THE SHOCK PROBLEM OUT. THANKS GUYS FOR ALL THE INFO ON FIXING THE SHOCK ISSUE. I ALSO WANNA GIVE A BIG SHOUT OUT TO CRAWLER DAD FOR ALL HIS HELP AND INPUT ON THIS BUILD FROM BEHIND THE SCENES. KEEP IN MIND THIS IS MY VERY FIRST EVER CRAWLER BUILD, SO THE LEARNING CURVE IS A LITTLE SLOW. LET ME KNOW WHAT YOU GUYS THINK SO FAR. PROBABLY GONNA BE ALITTLE WHILE BEFORE I CAN TOTALLY HAVE THIS BAD BOY HITTIN THE ROCKS, MONEY IS TIGHT. SOON AS I HAVE IT FINISHED, I'LL POST UP FINISHED PRODUCT PICS ON THIS THREAD.
11-12-2010, 11:28 AM | #16 |
Upper links go on the outside of the chassis.
11-12-2010, 12:05 PM | #17 |
Yup like Binary said the upper links need to be mounted outside of the chassis plates. Also, are you running a 60/40 setup? The rear shocks need to be stood up some more. |
11-12-2010, 12:09 PM | #18 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
Hey now if your gonna give me thx...you should be calling me before you post up silly pics like that..YOU NOOB Buy seriously..call me..so i can keep you on track with your build!! |
