11-29-2010, 05:58 AM | #21 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
11-29-2010, 06:01 AM | #22 |
11-29-2010, 06:02 AM | #23 |
11-29-2010, 06:09 AM | #24 |
11-29-2010, 06:17 AM | #25 |
| Cool, let me know when you want to go? Ill probably get out tue for some rock time. Im really curious to see what its capable of to start with. |
11-29-2010, 06:21 AM | #26 | |
I crawled npb Friday and Saturday and with out John's compressor there I am willing to be my motor is full of sand. Everything else is... I meant to check it out yesterday, but my back pain meds had me asleep ALL day. | |
11-29-2010, 09:48 AM | #27 | |
Rock Crawler Join Date: Jan 2009 Location: crawlorado
i may buy those from ya going the other way....rebuilding my fb sporty rig for those fun fill in nights | |
11-29-2010, 09:49 AM | #28 |
11-29-2010, 02:29 PM | #29 |
RCC Addict Join Date: Nov 2008 Location: I don't think theres rocks in Florida
I was wondering when you were going to post this up. Now its time to prove yourself.
11-29-2010, 07:49 PM | #30 |
11-30-2010, 07:07 AM | #31 |
Rock Crawler Join Date: Feb 2010 Location: chin ckeck
11-30-2010, 07:22 AM | #32 |
Do I need to get hardened pins for the mann gears? What pinions/motors are other people running? What track width (tire outside to outside) front and rear? Thanks for the help Last edited by billj; 11-30-2010 at 07:47 AM. |
11-30-2010, 07:40 AM | #33 |
11-30-2010, 07:55 AM | #34 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
I am still running stock(drilled) gears and stock pins. Almost a year now with no problems. (knock, knock, knock)
11-30-2010, 08:02 AM | #35 |
| But i have seen you and Richardgarrett56 both drive, you guys are smooth. I still have the "gas it, it will come out of there" attitude. But im trying to change my style |
11-30-2010, 05:56 PM | #36 |
Well finally got it out on some rocks for a shakedown run, got a few scratches on the axles Then a solder failure at the FXR and i puffed a battery Didnt get much time so hard to tell how the rig was doing. Got home and fixed the wire, and inverted the rear shocks(did the front yesterday) Last edited by billj; 11-30-2010 at 06:02 PM. |
11-30-2010, 05:57 PM | #37 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Looks good. Well? Do you like it?
11-30-2010, 06:39 PM | #38 |
12-01-2010, 07:20 AM | #39 |
Boy are you lucky with that solder failure, 10 minutes on the rocks with a brand new rig, it coulda been on fire! How were the rock at Markam?
12-01-2010, 07:33 AM | #40 |
After a closer look at your pics, use a piece of 1/4" delrin rod to tie the shocks together, at least the fronts. I worry about breaking the front off the chassis with out it as the chassis was designed with a cross member in that spot. Since we can't get new ones of we break them now, error on the side of caution. I have a bunch of 1/4" delrin rod if you are out to save you an order. Let me know and I will cut some for you tonight and bring it tomorrow along with your v2 CO caps for big bores. |
