05-26-2011, 11:06 PM | #41 |
05-26-2011, 11:08 PM | #42 |
05-26-2011, 11:10 PM | #43 | |
I hope to have it done for the comp. I will probably have zero drive time on it. LOL. Just waiting on one last part. After that as long as all the electronics work I can move pretty fast on getting this thing going. | |
05-26-2011, 11:14 PM | #44 |
| Before I got all these parts I was day dreaming. I really am not looking forward to the weight of the rear motor being where it is. Maybe I am just over thinking it? Anyway, while I was smoking some crack, I thought it would be a fun experiment to run a front/standard MOA axle and then for the rear, run a Losi axle with a motor mounted in the chassis with a simple underdrive with a drive line. Maybe even running the drive line way up high and make it a 2 piece drive line with some carrier bearings to make it out of the way. Maybe someday LOL |
05-26-2011, 11:16 PM | #45 |
| Thought about rear axles. They look like they would be super simple to make. I dont know what axlemaster is doing? He told me he does not have anymore and doesnt know if he will make more. Without his permission I would not be doing them.
05-26-2011, 11:18 PM | #46 |
05-26-2011, 11:27 PM | #47 |
I got some prototype shock mounts and a servo mount made up. I was planning on making the shock mounts out of aluminum but I made one out of Delrin first so I would not waste the AL before I got it right. After making one of the Delrin mounts I was really, really surprised at the strength, so surprised that I am going to give them a shot. Having never built a Berg I could use some feedback on the shock mounts. Do you guys think its worth doing the extra hole on top? Dealing with the Losi it seemed that I always needed something moved a touch here or a touch there. I figured it would be nice to have the option of moving the shock one more hole away from the link. I cant see any reason to not have it? It doesnt look like anything else is really even in the same area unless youre running backwards steering maybe? Maybe it will help with the shock clearance and crazy bent rear links? I still have some refining to do on both the servo and shock mounts. This is the basic ideas though. Taking a picture of something white is really tough. I dont have a picture but, for all those following along, servo mount and 4- shock mounts = 14g |
05-26-2011, 11:32 PM | #48 |
Again, one of the purposes of these shock mounts is being able to put them wherever you need. Up, down, closer or further from the motor. Two pictures to show how they can be adjusted (exaggerated). |
05-27-2011, 01:23 AM | #49 | |
Quarry Creeper Join Date: May 2009 Location: brentwood
05-27-2011, 03:44 AM | #50 |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
Speechless is all I can say?! .... And to think that there was nothing else for the berg .... Please do continue what your doing as I'm sure everyones saving up funds for paypal! |
05-27-2011, 05:03 AM | #51 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
Very nice work! Have you made a decision on what shafts to run in the rear? I'm really diggin those rear tubes and mounts!!!
05-27-2011, 05:07 AM | #52 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
Amazing work, definetly interested in the delrin tubes. Subscribed |
05-27-2011, 05:42 AM | #53 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
I need to stay out of the Berg section, or I am going to buy one but I gotta check up on my boys rigs.... The shock mounts look sweet, and I like the servo bracket. One of my favorite features of the berg is you can tuck the steering servo down in between the motor and axle tube, it is so clean and slick looking. This is gonna be a sweet biuld, I know you are making a lot of the berg guys pants dance. |
05-27-2011, 06:12 AM | #54 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Eric. I hear you talking a bit about the weight issues of the motor on the rear axle and I probably would have had similar concerns but you can undue that by running super light wheels.
05-27-2011, 06:48 AM | #55 | |
RCC Addict Join Date: Aug 2007 Location: Seattle
1. They're heavier then I like considering it's the tallest point of the axle 2. I need more axle separation. Not want. I run my top links low on the rear axle/ chassis side and it's not enough for our slick rocks. 3. It's not exactly center. I LOVE the shock mounts. More holes the better. I'll cut off any I won't use. | |
05-27-2011, 07:58 AM | #56 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Looks good. My only concern on your shock mounts is, how are they going to attach to keep them from moving? Delrin is pretty slippery! They would almost need a set screw or two going into the tube?? |
05-27-2011, 08:34 AM | #57 |
| Yep, they're not in the center of the axle...or at least if you mount one upper link to one side and one on the other...if you look from the back of the rig towards the chassis the driver side link will be closer to the driver rear tire...and the passenger side upper will be closer to the driver side rear tire than the passenger side rear. Whew...that was long winded. At this point I run the driver side upper mounted to the upper link mount and use a revo ball end on the passenger side to space the upper link over. Now they're even.
05-27-2011, 08:44 AM | #58 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Nice work, great to see you going a moa! Cheers Dan |
05-27-2011, 09:08 AM | #59 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
I think the lower link mounts are good, except for the slot cut in them, The links will put quite a bit of stress on them when digging or in a bind, it just looks like the slot would reduce the strength. How about an upper link mount in Delrin that has adjustment holes? It may or may not save some weight at the upper part of the axle, but it will have to be strong also. Everything else looks pretty damn nice! |
05-27-2011, 09:57 AM | #60 | |||||||||
I didnt have much choice in the matter. Stock or CKRC. I went with CKRC. We will see how good their "lifetime warranty" is. I am really surprised that you guys are having problems with a 6mm shaft. The Losi is far from a fire breathing dragon but with all the abuse I put that car through it never had a problem with the 4.5mm rear shafts. The 6mm shafts compared to the 4.5mm when held in your hands is pretty impressive. I doubt Losi uses as good of steel as the after market Berg does either. I will be really curios to see if making the inner diameter super tight on these axles will help with the shaft issues. I can see it being a problem since the i.d. of the stock Berg housings are 8mm and that lets the 6mm shaft deform and bend quite a bit under load. I wonder too if more people have problems if they tried to reduce the weight of their stock tubes and drilled them out to .500/12.5+mm Quote:
Feeler thread: Infinitely adjustable caster Quote:
Thanks Dan! Quote:
Thanks! | |||||||||
