06-13-2011, 11:05 PM | #121 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
its pretty large... a delrin base with a aluminum arm would be nice. almost like a losi shock arm. but smaller. maybe even carbon fiber?
06-13-2011, 11:16 PM | #122 | |
Its as wide as a stock mount and its going to look much bigger too since its almost 2x as tall and had to be thicker in order to get that driver side link in the right spot. | |
06-14-2011, 08:01 AM | #123 |
| It affects the roll axis and the stability of the rig in off camber situations. It also affects the arc in which the rear axle travels throughout the suspension cycle. The most basic effect it has is that it helps to keep the axle centered in the vehicle. Of course is is much more difficult than I can explain, but those are the basic ideas if I remember correctly. If you built it with a thin riser you can always use spacers or standoffs to adjust the mounting point, but if you build it with a wide riser you are stuck with adjusting outwards from there. |
06-14-2011, 10:05 AM | #124 |
RCC Addict Join Date: Aug 2007 Location: Seattle
I like it. I'm not sure on how much axle side separation is needed but that's a big step in the right direction. If you ever need a cold weather tester lmk what I can do. |
06-18-2011, 12:27 AM | #125 |
I ended up making some new panels. I am liking these much better. The rear of the cab was getting pretty beat up from rolling. |
06-18-2011, 12:29 AM | #126 |
I ended up taking Hulksta's advice and I turned down the O.D. of the big bores. Looks like a loss of 2g per shock. I didnt have any AL screws when I did the cap mod so I have some 4mm stainless screws in there that I would like to get out also. |
06-18-2011, 12:38 AM | #127 |
I think I finally settled on a rear link mount. Thanks to Tank for the great idea of making it adjustable from the outside I have been running this mount for the last couple of days and have some pretty abusive hours on it so far with zero issues. It is really nice to be able to adjust your motor up and down to get it exactly like you want and the mount has been very nice to adjust and do some tuning. I was running the top hole on some really sick/dusty rock. With that much anti squat it was really nice to try and grab some extra traction. When I went out and drove where the traction was really high, I had to take it down to the lowest hole or there was too much anti squat and I would get some hopping. After I figured that out, I adjusted my chassis for the least amount of anti squat possible so I can tune it all on the axle mount. It has been really nice and will be awesome to be able to adjust it depending on the terrain. Another nice feature that I have not tried yet is that the mount will allow you to run longer links without sacrificing the over all height. The way the mount ended up working is that I left the 3 adjustments in the inside of the case and then I did another 3 on the outside. If my thinking is right that means you can have 4 additional adjustments over stock. Course tune it on the inside of the case and then fine tune on the outside. Picture with the mount adjusted all the way back: Picture with the mount adjusted all the way forward: |
06-18-2011, 07:07 AM | #128 |
Very nice Erik! Now when can I send you some money?
06-18-2011, 07:54 AM | #129 |
Rock Crawler Join Date: Sep 2009 Location: The BYB Compound
Looks great Erik. I can't wait to get mine. How are the delrin tubes holding up to abuse. Those would be great to try also. Keep the superb parts coming.
06-18-2011, 08:39 PM | #130 |
06-18-2011, 08:41 PM | #131 | |
The tubes are holding up great! So good that its tempting to cut them down some more. I think there is little gain in that though so I am going to leave it as is. I wish I had a long laundry list of broken parts to show that I am being rough on this thing. The only issues I have had are screws coming loose, on every part of this car. I am putting loc tite on them as they come loose. After cartwheeling 15 feet or so down a brutal rock, 53 Willys said something to the effect of: "Man, atleast youre putting that thing through its course". I think thats code for "Man, learn how to drive". | |
06-18-2011, 08:58 PM | #132 |
Rock Crawler Join Date: Jun 2008 Location: South Ogden, Utah
can you offer the tubes in black?
06-18-2011, 09:21 PM | #133 |
06-18-2011, 09:48 PM | #134 | |
I wanna be Dave Join Date: Jan 2009 Location: laying low
he is putting a beating on these parts forsure!! for the record you are a great driver....this berg seems to have made you an even better driver | |
06-18-2011, 11:58 PM | #135 |
06-18-2011, 11:58 PM | #136 |
06-18-2011, 11:59 PM | #137 | |
06-19-2011, 01:14 AM | #138 |
Rock Crawler Join Date: Mar 2010 Location: England & SoFlo
| Great news!! Couple of weeks and hopefully i'll be able to order up tubes etc in black. Great work Erik Last edited by vodka child; 06-19-2011 at 01:13 PM. |
06-19-2011, 01:07 PM | #139 |
Glad to hear everything is testing well. I've really like your products. Any guestate on tube cost? I'm only looking at doing the rear for now and a pm reply is fine. Thanks for doing what you do! |
06-20-2011, 12:13 PM | #140 | ||
I sent a PM on tubes. I actually gave a guess on the front/rear though so you can cut that in half. | ||
