03-13-2015, 11:14 AM | #1481 |
| Re: Dlux Berg Build
I've seen this trickery and strategery! Post #1477 and video.. The whole :15-:30 second range.. Front wheels are spinning forward, rear in reverse.. You stick guys! Mr. Fest didn't like when I called a reverse on a situation like that.. Most ppl miss good stuff like this! ;) |
03-13-2015, 11:20 AM | #1482 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
| Re: Dlux Berg Build
I mean when you run the rear axle in reverse there shall be 1 point,, does not matter if you still going forward with the front axle....
03-13-2015, 11:38 AM | #1483 | |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: Dlux Berg Build Quote:
03-13-2015, 01:22 PM | #1484 |
| Re: Dlux Berg Build
I do see that being the biggest side of stick. Dual motor rotation. I would like to see the difference in the bounty lines with a MT-4 tho.. It can, with the user's ability, do the rest of the stuff. (Atleast in the situations mentioned) Maybe not the same as a stick, but a whole lot better of a shot then button pushing.. |
03-13-2015, 01:38 PM | #1485 |
| Re: Dlux Berg Build
Yeah, the MT-4 interests me. I may order one for the "Kids build" to check it out. Edit: $200 for the MT4? F that. |
03-13-2015, 03:54 PM | #1486 |
RCC Addict Join Date: May 2012 Location: Folsom
| Re: Dlux Berg Build
That must be mt 4s. The new model. It think there is an older one
03-13-2015, 04:44 PM | #1487 | |
Specially considering the higher prices of Lesser radios. The MT-4s is 300$.. (When it came out) | |
03-16-2015, 09:10 AM | #1488 |
| Re: Dlux Berg Build
Getting pretty stoked about the BOTW. I decided to make a trip out this last weekend to do some event planning and also to do some driving. https://youtu.be/PMY-FMFJDU0 https://youtu.be/LDJrP2IAUR8 |
03-16-2015, 10:23 AM | #1489 |
| Re: Dlux Berg Build
damn I envy you that location to crawl on... here in Norway the best places is by the sea,, and we have some pretty great spots along oure shoreline.. specially here in the far north off norway,,67* North.. over the polar circle.. |
04-01-2015, 12:12 PM | #1490 |
| Re: Dlux Berg Build
Hey! question..... I had one of my king pins come loose and lost the hollow ball that goes in the bearing for your knuckles. I replaced it with a filed down traxxas hollow ball but now there is a little bit of slop. What hollow balls are you using? |
04-21-2015, 06:48 PM | #1491 | |
The little red lever on the handle controlled proportional mixing while the push button wasn't pressed. When the push button was pressed the trigger had full control of the front and the red lever had full control of the rear. It was amazing. Anyways, if forwards/backwards at the same time is legal, I am so totally going to make a stick mod for the flyskys' As for your other pistol grip radio issues. It sounds like my normal MOA setup would satisfy all the other issues you had There are two rockers and a push buttons on the grip On one of the rockers, I had it setup for momentary dig. Just bump it one way or the other and it goes to full dig. Let off of the switch and it goes back to center. You can do this at any current mix settings, and it'll return to the previous mix. Then on the other rocker I had 10% steps setup. and a long click set to bring my mix to full dig for the corresponding direction. (I had my long click length set to like 1/5 of a second). So I had quick access to the low propo values and the high propo values. Then on my push button. It would bring me back to even mix One feature i've wanted to add was to be able to adjust my "previous value" using my propo switch while I had dig engaged using my momentary so I could revert back to a different mix setting after returning from a momentary dig. Edit: Also, something you can't do with a stick...(this may not work if you're running drag brake, I had a lcc moa ) But I could rapidly press my dig button (many times per second), and it would give me better bite while climbing. The front would get a hard dig bite but then lose it and get pushed a little by the rear. This kept the suspension pretty relaxed and help get up the stuff where the tires just slipped....I mainly used it on spots where if the rear had propo it would throw you off the line but if it was dead it would just be an anchor. Last edited by losikid; 04-21-2015 at 07:01 PM. | |
04-21-2015, 08:06 PM | #1492 |
| Re: Dlux Berg Build
Fwd/backwards, at the same time, isn't "illegal".. It's just a reverse penalty.. But from what I've seen Turbofest do, the line he saved or took, from taking a 1 point reverse.. Saving him from falling off a rock, completely lose the line, roll over, gate, etc.. Well worth the 1 point.. IMO.. That tq3 looks like a electronic switch porcupine! Lol.. How does 1 thumb do all that stuff? ;) I'm SO glad for the MT-4. All but the independent rear option, is all on 1 lever.. If you can figure that out for the MT-4, you sir, will have a new customer! |
04-21-2015, 08:39 PM | #1493 | |
I've always wanted to buy a mt4 and tinker. But never enough to fork over the cash to buy one. Maybe someday... I don't want to stuff up eriks thread too much. But this is a porcupine radio...two dx3e's stuffed into each one. | |
04-21-2015, 10:26 PM | #1494 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Dude, if this radio was less complicated than the stick radio you were using, IDK. That is some craziness. The only mod i have to my 6EX is the self centering sticks and i can think of two ways to accomplish your scenario. 1, because the right and left sticks can control the axles independently, i could give power to the front axle with the left stick and bump the right stick the intermittently turn the rear tires. 2, while in dig i could just use the right stick to give power and use my right index finger to flick the dig switch back and forth really fast and accomplish the exact same thing you are talking about. Personally, if i needed to use one of these i would opt for the first one because i would then be able to control the amount of power being fed to each axle. But i find i have much better results if i give the front axle more power and slowly feed in the rear motor smoothly. | |
04-22-2015, 02:00 PM | #1495 | |
Time ! | |
04-23-2015, 07:35 AM | #1496 |
| Re: Dlux Berg Build
4:20?
04-29-2015, 08:52 AM | #1497 |
| Re: Dlux Berg Build
Got me some new tires, finally. I have always been interested in the narrow tires. Problem was that I dont like cutting them and when I am known to go through tires so quickly (I have gone through a set of Sedonas in less than 1 month) I didnt want the cost nor the inconvenience of custom tires. Well... Wheels7 has been beating me up pretty good in our local comps, enough to see the benefit of a narrow tire, so I had no choice. Big thanks to Wheels7 for cutting up the rovers and Voodoo. After he showed me some tricks, I did the Sedonas myself. No where near perfect but good enough for me. I think I have finally whittled down my tire choices too. I dont think the bluedoos will come off the rear, ever and for the fronts, it pretty much depends on the weather. Silver/gold Voodoo for under 50*, ridiculous narrow Sedona for under 80* and blue Rover for anything over 80*. Been sticking with this and been super happy so far. Shot of the narrow Rovers and bluedoos Ridiculous narrow Sedonas and bluedoos. Not the best shot. I can get a closer pic if anybody is interested. |
04-29-2015, 09:10 AM | #1498 |
| Re: Dlux Berg Build
Wow, your running Rovers? haha
04-29-2015, 09:13 AM | #1499 |
| Re: Dlux Berg Build
Been running Rovers for almost a year now. After discovering the blue compound, I have a hard time going back to a Sedona.
04-29-2015, 09:21 AM | #1500 |
| Re: Dlux Berg Build
I've never ran a blue Rover. What do you like about them over a White? I couldn't imagine why you would need to narrow a rover, they are so skinny already, especially once you shave the sidewalls. I have never heard anything good about the Blue's, just that new people bought them by accident not knowing there was a difference.
